My kids play games with a friend who is visually impaired. The thought went up, can the CP speak? According to Adadfuit's example code the answer is yes...but it is a finicky beast to hear. I put the code in from their example code and worked it into the flow of the Dice Bag code. When you release the button it will not only show you the results on the Neopixels but also speak it from that teeeeny tiny speaker on the CP.
This is the first stab at a solution. I am going to try some of the other speech code to see if those are more understandable on this speaker.
Another idea was to uses beeps to give the results of the dice throw. If the speech does not pan out in testing we might go that route.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_CircuitPlayground.h>
The Circuit Playground Dice Bag - CC Attribution-ShareAlike 4.0 International Tom Higgins & Sons
TO select the type of die you would like to throw
First put the Select Switch in the proper position
Then press the proper Button
Select Switch Left Button Right Button
+ | d100 (0-99)| d20 (1-20) |
- | d12 (1-12)| d06 (1-6) |
You can hold down the Button and it will flash through many tosses.
Release the Button and your results will show on the Circuit Playground as
two (or one) lit NeoPixel
Red=Tens Place (0-9)
Blue=Ones Place (0-9)
Green=Tens and Ones are the same (00,11,22,33,44,55,66,77,88,99)
The NeoPixels are arranged from 0 - 9 . If you are holding your Circuit Playground with the USB port facing Up
0 is the top left NeoPixel closest to the USB port
1 is to the left of that
4 is the bottom let NeoPixel closest to the Battery Jack
5 is the bottom right NeoPixel closest to the Battery Jack
9 is the top tight NeoPixel closest to the USB port
const uint8_t spZERO[] PROGMEM = {0x69,0xFB,0x59,0xDD,0x51,0xD5,0xD7,0xB5,0x6F,0x0A,0x78,0xC0,0x52,0x01,0x0F,0x50,0xAC,0xF6,0xA8,0x16,0x15,0xF2,0x7B,0xEA,0x19,0x47,0xD0,0x64,0xEB,0xAD,0x76,0xB5,0xEB,0xD1,0x96,0x24,0x6E,0x62,0x6D,0x5B,0x1F,0x0A,0xA7,0xB9,0xC5,0xAB,0xFD,0x1A,0x62,0xF0,0xF0,0xE2,0x6C,0x73,0x1C,0x73,0x52,0x1D,0x19,0x94,0x6F,0xCE,0x7D,0xED,0x6B,0xD9,0x82,0xDC,0x48,0xC7,0x2E,0x71,0x8B,0xBB,0xDF,0xFF,0x1F};
//const uint8_t spONE[] PROGMEM = {0x66,0x4E,0xA8,0x7A,0x8D,0xED,0xC4,0xB5,0xCD,0x89,0xD4,0xBC,0xA2,0xDB,0xD1,0x27,0xBE,0x33,0x4C,0xD9,0x4F,0x9B,0x4D,0x57,0x8A,0x76,0xBE,0xF5,0xA9,0xAA,0x2E,0x4F,0xD5,0xCD,0xB7,0xD9,0x43,0x5B,0x87,0x13,0x4C,0x0D,0xA7,0x75,0xAB,0x7B,0x3E,0xE3,0x19,0x6F,0x7F,0xA7,0xA7,0xF9,0xD0,0x30,0x5B,0x1D,0x9E,0x9A,0x34,0x44,0xBC,0xB6,0x7D,0xFE,0x1F};
//const uint8_t spTWO[] PROGMEM = {0x06,0xB8,0x59,0x34,0x00,0x27,0xD6,0x38,0x60,0x58,0xD3,0x91,0x55,0x2D,0xAA,0x65,0x9D,0x4F,0xD1,0xB8,0x39,0x17,0x67,0xBF,0xC5,0xAE,0x5A,0x1D,0xB5,0x7A,0x06,0xF6,0xA9,0x7D,0x9D,0xD2,0x6C,0x55,0xA5,0x26,0x75,0xC9,0x9B,0xDF,0xFC,0x6E,0x0E,0x63,0x3A,0x34,0x70,0xAF,0x3E,0xFF,0x1F};
//const uint8_t spTHREE[] PROGMEM = {0x0C,0xE8,0x2E,0x94,0x01,0x4D,0xBA,0x4A,0x40,0x03,0x16,0x68,0x69,0x36,0x1C,0xE9,0xBA,0xB8,0xE5,0x39,0x70,0x72,0x84,0xDB,0x51,0xA4,0xA8,0x4E,0xA3,0xC9,0x77,0xB1,0xCA,0xD6,0x52,0xA8,0x71,0xED,0x2A,0x7B,0x4B,0xA6,0xE0,0x37,0xB7,0x5A,0xDD,0x48,0x8E,0x94,0xF1,0x64,0xCE,0x6D,0x19,0x55,0x91,0xBC,0x6E,0xD7,0xAD,0x1E,0xF5,0xAA,0x77,0x7A,0xC6,0x70,0x22,0xCD,0xC7,0xF9,0x89,0xCF,0xFF,0x03};
//const uint8_t spFOUR[] PROGMEM = {0x08,0x68,0x21,0x0D,0x03,0x04,0x28,0xCE,0x92,0x03,0x23,0x4A,0xCA,0xA6,0x1C,0xDA,0xAD,0xB4,0x70,0xED,0x19,0x64,0xB7,0xD3,0x91,0x45,0x51,0x35,0x89,0xEA,0x66,0xDE,0xEA,0xE0,0xAB,0xD3,0x29,0x4F,0x1F,0xFA,0x52,0xF6,0x90,0x52,0x3B,0x25,0x7F,0xDD,0xCB,0x9D,0x72,0x72,0x8C,0x79,0xCB,0x6F,0xFA,0xD2,0x10,0x9E,0xB4,0x2C,0xE1,0x4F,0x25,0x70,0x3A,0xDC,0xBA,0x2F,0x6F,0xC1,0x75,0xCB,0xF2,0xFF};
//const uint8_t spFIVE[] PROGMEM = {0x08,0x68,0x4E,0x9D,0x02,0x1C,0x60,0xC0,0x8C,0x69,0x12,0xB0,0xC0,0x28,0xAB,0x8C,0x9C,0xC0,0x2D,0xBB,0x38,0x79,0x31,0x15,0xA3,0xB6,0xE4,0x16,0xB7,0xDC,0xF5,0x6E,0x57,0xDF,0x54,0x5B,0x85,0xBE,0xD9,0xE3,0x5C,0xC6,0xD6,0x6D,0xB1,0xA5,0xBF,0x99,0x5B,0x3B,0x5A,0x30,0x09,0xAF,0x2F,0xED,0xEC,0x31,0xC4,0x5C,0xBE,0xD6,0x33,0xDD,0xAD,0x88,0x87,0xE2,0xD2,0xF2,0xF4,0xE0,0x16,0x2A,0xB2,0xE3,0x63,0x1F,0xF9,0xF0,0xE7,0xFF,0x01};
//const uint8_t spSIX[] PROGMEM = {0x04,0xF8,0xAD,0x4C,0x02,0x16,0xB0,0x80,0x06,0x56,0x35,0x5D,0xA8,0x2A,0x6D,0xB9,0xCD,0x69,0xBB,0x2B,0x55,0xB5,0x2D,0xB7,0xDB,0xFD,0x9C,0x0D,0xD8,0x32,0x8A,0x7B,0xBC,0x02,0x00,0x03,0x0C,0xB1,0x2E,0x80,0xDF,0xD2,0x35,0x20,0x01,0x0E,0x60,0xE0,0xFF,0x01};
//const uint8_t spSEVEN[] PROGMEM = {0x0C,0xF8,0x5E,0x4C,0x01,0xBF,0x95,0x7B,0xC0,0x02,0x16,0xB0,0xC0,0xC8,0xBA,0x36,0x4D,0xB7,0x27,0x37,0xBB,0xC5,0x29,0xBA,0x71,0x6D,0xB7,0xB5,0xAB,0xA8,0xCE,0xBD,0xD4,0xDE,0xA6,0xB2,0x5A,0xB1,0x34,0x6A,0x1D,0xA7,0x35,0x37,0xE5,0x5A,0xAE,0x6B,0xEE,0xD2,0xB6,0x26,0x4C,0x37,0xF5,0x4D,0xB9,0x9A,0x34,0x39,0xB7,0xC6,0xE1,0x1E,0x81,0xD8,0xA2,0xEC,0xE6,0xC7,0x7F,0xFE,0xFB,0x7F};
//const uint8_t spEIGHT[] PROGMEM = {0x65,0x69,0x89,0xC5,0x73,0x66,0xDF,0xE9,0x8C,0x33,0x0E,0x41,0xC6,0xEA,0x5B,0xEF,0x7A,0xF5,0x33,0x25,0x50,0xE5,0xEA,0x39,0xD7,0xC5,0x6E,0x08,0x14,0xC1,0xDD,0x45,0x64,0x03,0x00,0x80,0x00,0xAE,0x70,0x33,0xC0,0x73,0x33,0x1A,0x10,0x40,0x8F,0x2B,0x14,0xF8,0x7F};
//const uint8_t spNINE[] PROGMEM = {0xE6,0xA8,0x1A,0x35,0x5D,0xD6,0x9A,0x35,0x4B,0x8C,0x4E,0x6B,0x1A,0xD6,0xA6,0x51,0xB2,0xB5,0xEE,0x58,0x9A,0x13,0x4F,0xB5,0x35,0x67,0x68,0x26,0x3D,0x4D,0x97,0x9C,0xBE,0xC9,0x75,0x2F,0x6D,0x7B,0xBB,0x5B,0xDF,0xFA,0x36,0xA7,0xEF,0xBA,0x25,0xDA,0x16,0xDF,0x69,0xAC,0x23,0x05,0x45,0xF9,0xAC,0xB9,0x8F,0xA3,0x97,0x20,0x73,0x9F,0x54,0xCE,0x1E,0x45,0xC2,0xA2,0x4E,0x3E,0xD3,0xD5,0x3D,0xB1,0x79,0x24,0x0D,0xD7,0x48,0x4C,0x6E,0xE1,0x2C,0xDE,0xFF,0x0F};
//const uint8_t spTEN[] PROGMEM = {0x0E,0x38,0x3C,0x2D,0x00,0x5F,0xB6,0x19,0x60,0xA8,0x90,0x93,0x36,0x2B,0xE2,0x99,0xB3,0x4E,0xD9,0x7D,0x89,0x85,0x2F,0xBE,0xD5,0xAD,0x4F,0x3F,0x64,0xAB,0xA4,0x3E,0xBA,0xD3,0x59,0x9A,0x2E,0x75,0xD5,0x39,0x6D,0x6B,0x0A,0x2D,0x3C,0xEC,0xE5,0xDD,0x1F,0xFE,0xB0,0xE7,0xFF,0x03};
//const uint8_t spELEVEN[] PROGMEM = {0xA5,0xEF,0xD6,0x50,0x3B,0x67,0x8F,0xB9,0x3B,0x23,0x49,0x7F,0x33,0x87,0x31,0x0C,0xE9,0x22,0x49,0x7D,0x56,0xDF,0x69,0xAA,0x39,0x6D,0x59,0xDD,0x82,0x56,0x92,0xDA,0xE5,0x74,0x9D,0xA7,0xA6,0xD3,0x9A,0x53,0x37,0x99,0x56,0xA6,0x6F,0x4F,0x59,0x9D,0x7B,0x89,0x2F,0xDD,0xC5,0x28,0xAA,0x15,0x4B,0xA3,0xD6,0xAE,0x8C,0x8A,0xAD,0x54,0x3B,0xA7,0xA9,0x3B,0xB3,0x54,0x5D,0x33,0xE6,0xA6,0x5C,0xCB,0x75,0xCD,0x5E,0xC6,0xDA,0xA4,0xCA,0xB9,0x35,0xAE,0x67,0xB8,0x46,0x40,0xB6,0x28,0xBB,0xF1,0xF6,0xB7,0xB9,0x47,0x20,0xB6,0x28,0xBB,0xFF,0x0F};
//const uint8_t spTWELVE[] PROGMEM = {0x09,0x98,0xDA,0x22,0x01,0x37,0x78,0x1A,0x20,0x85,0xD1,0x50,0x3A,0x33,0x11,0x81,0x5D,0x5B,0x95,0xD4,0x44,0x04,0x76,0x9D,0xD5,0xA9,0x3A,0xAB,0xF0,0xA1,0x3E,0xB7,0xBA,0xD5,0xA9,0x2B,0xEB,0xCC,0xA0,0x3E,0xB7,0xBD,0xC3,0x5A,0x3B,0xC8,0x69,0x67,0xBD,0xFB,0xE8,0x67,0xBF,0xCA,0x9D,0xE9,0x74,0x08,0xE7,0xCE,0x77,0x78,0x06,0x89,0x32,0x57,0xD6,0xF1,0xF1,0x8F,0x7D,0xFE,0x1F};
//const uint8_t spTWENTY[] PROGMEM = {0x0A,0xE8,0x4A,0xCD,0x01,0xDB,0xB9,0x33,0xC0,0xA6,0x54,0x0C,0xA4,0x34,0xD9,0xF2,0x0A,0x6C,0xBB,0xB3,0x53,0x0E,0x5D,0xA6,0x25,0x9B,0x6F,0x75,0xCA,0x61,0x52,0xDC,0x74,0x49,0xA9,0x8A,0xC4,0x76,0x4D,0xD7,0xB1,0x76,0xC0,0x55,0xA6,0x65,0xD8,0x26,0x99,0x5C,0x56,0xAD,0xB9,0x25,0x23,0xD5,0x7C,0x32,0x96,0xE9,0x9B,0x20,0x7D,0xCB,0x3C,0xFA,0x55,0xAE,0x99,0x1A,0x30,0xFC,0x4B,0x3C,0xFF,0x1F};
//const uint8_t spHUNDRED[] PROGMEM = {0x04,0xC8,0x7E,0x5C,0x02,0x0A,0xA8,0x62,0x43,0x03,0xA7,0xA8,0x62,0x43,0x4B,0x97,0xDC,0xF2,0x14,0xC5,0xA7,0x9B,0x7A,0xD3,0x95,0x37,0xC3,0x1E,0x16,0x4A,0x66,0x36,0xF3,0x5A,0x89,0x6E,0xD4,0x30,0x55,0xB5,0x32,0xB7,0x31,0xB5,0xC1,0x69,0x2C,0xE9,0xF7,0xBC,0x96,0x12,0x39,0xD4,0xB5,0xFD,0xDA,0x9B,0x0F,0xD1,0x90,0xEE,0xF5,0xE4,0x17,0x02,0x45,0x28,0x77,0x11,0xD9,0x40,0x9E,0x45,0xDD,0x2B,0x33,0x71,0x7A,0xBA,0x0B,0x13,0x95,0x2D,0xF9,0xF9,0x7F};
const uint8_t spONE[] PROGMEM = {0xCC,0x67,0x75,0x42,0x59,0x5D,0x3A,0x4F,0x9D,0x36,0x63,0xB7,0x59,0xDC,0x30,0x5B,0x5C,0x23,0x61,0xF3,0xE2,0x1C,0xF1,0xF0,0x98,0xC3,0x4B,0x7D,0x39,0xCA,0x1D,0x2C,0x2F,0xB7,0x15,0xEF,0x70,0x79,0xBC,0xD2,0x46,0x7C,0x52,0xE5,0xF1,0x4A,0x6A,0xB3,0x71,0x47,0xC3,0x2D,0x39,0x34,0x4B,0x23,0x35,0xB7,0x7A,0x55,0x33,0x8F,0x59,0xDC,0xA2,0x44,0xB5,0xBC,0x66,0x72,0x8B,0x64,0xF5,0xF6,0x98,0xC1,0x4D,0x42,0xD4,0x27,0x62,0x38,0x2F,0x4A,0xB6,0x9C,0x88,0x68,0xBC,0xA6,0x95,0xF8,0x5C,0xA1,0x09,0x86,0x77,0x91,0x11,0x5B,0xFF,0x0F};
const uint8_t spTWO[] PROGMEM = {0x0E,0x38,0x6E,0x25,0x00,0xA3,0x0D,0x3A,0xA0,0x37,0xC5,0xA0,0x05,0x9E,0x56,0x35,0x86,0xAA,0x5E,0x8C,0xA4,0x82,0xB2,0xD7,0x74,0x31,0x22,0x69,0xAD,0x1C,0xD3,0xC1,0xD0,0xFA,0x28,0x2B,0x2D,0x47,0xC3,0x1B,0xC2,0xC4,0xAE,0xC6,0xCD,0x9C,0x48,0x53,0x9A,0xFF,0x0F};
const uint8_t spTHREE[] PROGMEM = {0x02,0xD8,0x2E,0x9C,0x01,0xDB,0xA6,0x33,0x60,0xFB,0x30,0x01,0xEC,0x20,0x12,0x8C,0xE4,0xD8,0xCA,0x32,0x96,0x73,0x63,0x41,0x39,0x89,0x98,0xC1,0x4D,0x0D,0xED,0xB0,0x2A,0x05,0x37,0x0F,0xB4,0xA5,0xAE,0x5C,0xDC,0x36,0xD0,0x83,0x2F,0x4A,0x71,0x7B,0x03,0xF7,0x38,0x59,0xCD,0xED,0x1E,0xB4,0x6B,0x14,0x35,0xB7,0x6B,0x94,0x99,0x91,0xD5,0xDC,0x26,0x48,0x77,0x4B,0x66,0x71,0x1B,0x21,0xDB,0x2D,0x8A,0xC9,0x6D,0x88,0xFC,0x26,0x28,0x3A,0xB7,0x21,0xF4,0x1F,0xA3,0x65,0xBC,0x02,0x38,0xBB,0x3D,0x8E,0xF0,0x2B,0xE2,0x08,0xB7,0x34,0xFF,0x0F};
const uint8_t spFOUR[] PROGMEM = {0x0C,0x18,0xB6,0x9A,0x01,0xC3,0x75,0x09,0x60,0xD8,0x0E,0x09,0x30,0xA0,0x9B,0xB6,0xA0,0xBB,0xB0,0xAA,0x16,0x4E,0x82,0xEB,0xEA,0xA9,0xFA,0x59,0x49,0x9E,0x59,0x23,0x9A,0x27,0x3B,0x78,0x66,0xAE,0x4A,0x9C,0x9C,0xE0,0x99,0xD3,0x2A,0xBD,0x72,0x92,0xEF,0xE6,0x88,0xE4,0x45,0x4D,0x7E,0x98,0x2D,0x62,0x67,0x37,0xF9,0xA1,0x37,0xA7,0x6C,0x94,0xE4,0xC7,0x1E,0xDC,0x3C,0xA5,0x83,0x1F,0x8B,0xEB,0x52,0x0E,0x0E,0x7E,0x2E,0x4E,0xC7,0x31,0xD2,0x79,0xA5,0x3A,0x0D,0xD9,0xC4,0xFF,0x07};
const uint8_t spFIVE[] PROGMEM = {0x02,0xE8,0x3E,0x8C,0x01,0xDD,0x65,0x08,0x60,0x98,0x4C,0x06,0x34,0x93,0xCE,0x80,0xE6,0xDA,0x9A,0x14,0x6B,0xAA,0x47,0xD1,0x5E,0x56,0xAA,0x6D,0x56,0xCD,0x78,0xD9,0xA9,0x1C,0x67,0x05,0x83,0xE1,0xA4,0xBA,0x38,0xEE,0x16,0x86,0x9B,0xFA,0x60,0x87,0x5B,0x18,0x6E,0xEE,0x8B,0x1D,0x6E,0x61,0xB9,0x69,0x36,0x65,0xBA,0x8D,0xE5,0xE5,0x3E,0x1C,0xE9,0x0E,0x96,0x9B,0x5B,0xAB,0x95,0x2B,0x58,0x6E,0xCE,0xE5,0x3A,0x6A,0xF3,0xB8,0x35,0x84,0x7B,0x05,0xA3,0xE3,0x36,0xEF,0x92,0x19,0xB4,0x86,0xDB,0xB4,0x69,0xB4,0xD1,0x2A,0x4E,0x65,0x9A,0x99,0xCE,0x28,0xD9,0x85,0x71,0x4C,0x18,0x6D,0x67,0x47,0xC6,0x5E,0x53,0x4A,0x9C,0xB5,0xE2,0x85,0x45,0x26,0xFE,0x7F};
const uint8_t spSIX[] PROGMEM = {0x0E,0xD8,0xAE,0xDD,0x03,0x0E,0x38,0xA6,0xD2,0x01,0xD3,0xB4,0x2C,0xAD,0x6A,0x35,0x9D,0xB1,0x7D,0xDC,0xEE,0xC4,0x65,0xD7,0xF1,0x72,0x47,0x24,0xB3,0x19,0xD9,0xD9,0x05,0x70,0x40,0x49,0xEA,0x02,0x98,0xBE,0x42,0x01,0xDF,0xA4,0x69,0x40,0x00,0xDF,0x95,0xFC,0x3F};
const uint8_t spSEVEN[] PROGMEM = {0x02,0xB8,0x3A,0x8C,0x01,0xDF,0xA4,0x73,0x40,0x01,0x47,0xB9,0x2F,0x33,0x3B,0x73,0x5F,0x53,0x7C,0xEC,0x9A,0xC5,0x63,0xD5,0xD1,0x75,0xAE,0x5B,0xFC,0x64,0x5C,0x35,0x87,0x91,0xF1,0x83,0x36,0xB5,0x68,0x55,0xC5,0x6F,0xDA,0x45,0x2D,0x1C,0x2D,0xB7,0x38,0x37,0x9F,0x60,0x3C,0xBC,0x9A,0x85,0xA3,0x25,0x66,0xF7,0x8A,0x57,0x1C,0xA9,0x67,0x56,0xCA,0x5E,0xF0,0xB2,0x16,0xB2,0xF1,0x89,0xCE,0x8B,0x92,0x25,0xC7,0x2B,0x33,0xCF,0x48,0xB1,0x99,0xB4,0xF3,0xFF};
const uint8_t spEIGHT[] PROGMEM = {0xC3,0x6C,0x86,0xB3,0x27,0x6D,0x0F,0xA7,0x48,0x99,0x4E,0x55,0x3C,0xBC,0x22,0x65,0x36,0x4D,0xD1,0xF0,0x32,0xD3,0xBE,0x34,0xDA,0xC3,0xEB,0x82,0xE2,0xDA,0x65,0x35,0xAF,0x31,0xF2,0x6B,0x97,0x95,0xBC,0x86,0xD8,0x6F,0x82,0xA6,0x73,0x0B,0xC6,0x9E,0x72,0x99,0xCC,0xCB,0x02,0xAD,0x3C,0x9A,0x10,0x60,0xAB,0x62,0x05,0x2C,0x37,0x84,0x00,0xA9,0x73,0x00,0x00,0xFE,0x1F};
const uint8_t spNINE[] PROGMEM = {0xCC,0xA1,0x26,0xBB,0x83,0x93,0x18,0xCF,0x4A,0xAD,0x2E,0x31,0xED,0x3C,0xA7,0x24,0x26,0xC3,0x54,0xF1,0x92,0x64,0x8B,0x8A,0x98,0xCB,0x2B,0x2E,0x34,0x53,0x2D,0x0E,0x2F,0x57,0xB3,0x0C,0x0D,0x3C,0xBC,0x3C,0x4C,0x4B,0xCA,0xF4,0xF0,0x72,0x0F,0x6E,0x49,0x53,0xCD,0xCB,0x53,0x2D,0x35,0x4D,0x0F,0x2F,0x0F,0xD7,0x0C,0x0D,0x3D,0xBC,0xDC,0x4D,0xD3,0xDD,0xC2,0xF0,0x72,0x52,0x4F,0x57,0x9B,0xC3,0xAB,0x89,0xBD,0x42,0x2D,0x0F,0xAF,0x5A,0xD1,0x71,0x91,0x55,0xBC,0x2C,0xC5,0x3B,0xD8,0x65,0xF2,0x82,0x94,0x18,0x4E,0x3B,0xC1,0x73,0x42,0x32,0x33,0x15,0x45,0x4F,0x79,0x52,0x6A,0x55,0xA6,0xA3,0xFF,0x07};
const uint8_t spPAUSE1[] PROGMEM = {0x00,0x00,0x00,0x00,0xFF,0x0F};
int troll = 0;
int ones = 0;
int tens = 0;
void setup()
Serial.begin(9600);
randomSeed(analogRead(0));
CircuitPlayground.begin();
void loop()
CircuitPlayground.setBrightness((CircuitPlayground.lightSensor()+4)/4); //variable neopixel birghtness based on current light level
if (CircuitPlayground.slideSwitch()) {
if (CircuitPlayground.leftButton()) {tossd100();}
if (CircuitPlayground.rightButton()) {tossd20();}
else
if (CircuitPlayground.leftButton()) {tossd12();}
if (CircuitPlayground.rightButton()) {tossd06();}
void tossd100() { // function for d100
troll = random(0,99);
prepthrow(troll);
void tossd20() { // function for d20
troll = random(1,21);
prepthrow(troll);
void tossd12() { // function for d12
troll = random(1,13);
prepthrow(troll);
void tossd06() { // function for d6
troll = random(1,7);
prepthrow(troll);
void prepthrow(int troll) { // function to take the roll and parse it to tens and ones
Serial.println(" "); // print throw results to the console
Serial.print("Throw was a ");
Serial.print(troll);
ones=troll % 10;
tens=troll / 10;
showtoss(ones,tens);
void showtoss(int ones,int tens) { // function to display the results on the neopixels
Serial.print(" tens-"); // print the tens and ones breakdown to console
Serial.print(tens);
Serial.print(" ones-");
Serial.print(ones);
CircuitPlayground.clearPixels();
CircuitPlayground.playTone((ones*100)+1, 50); // attemped to make it sound like dice being rolled
CircuitPlayground.speaker.end();
if (!CircuitPlayground.leftButton() && !CircuitPlayground.rightButton()){
speakroll(tens);
speakroll(ones);
if (ones==tens){
CircuitPlayground.setPixelColor(tens, 5, 255, 5); // if ones and tens are the same show as green
else {
CircuitPlayground.setPixelColor(ones, 5, 5, 255); // show ones as blue
CircuitPlayground.setPixelColor(tens, 255, 5, 5); } // show tens as red
void speakroll(int digit) {
switch (digit) {
case 0:
CircuitPlayground.speaker.say(spZERO);
break;
case 1:
CircuitPlayground.speaker.say(spONE);
break;
case 2:
CircuitPlayground.speaker.say(spTWO);
break;
case 3:
CircuitPlayground.speaker.say(spTHREE);
break;
case 4:
CircuitPlayground.speaker.say(spFOUR);
break;
case 5:
CircuitPlayground.speaker.say(spFIVE);
break;
case 6:
CircuitPlayground.speaker.say(spSIX);
break;
case 7:
CircuitPlayground.speaker.say(spSEVEN);
break;
case 8:
CircuitPlayground.speaker.say(spEIGHT);
break;
case 9:
CircuitPlayground.speaker.say(spNINE);
break;
default:
break;
CircuitPlayground.speaker.say(spPAUSE1);
