In preparing for Adafruit's new version of the Circuit Playground I started using the web browser based dev environment over at http://makecode.adafruit.com
You can find this up there at https://makecode.com/_MJjJrg9eRTmi
The Circuit Playground Dice Bag - CC Attribution-ShareAlike - Tom Higgins and Sons
User Manual
Select the type of die you would like to throw by setting the Select Switch
and pressing one of the Buttons
Select Switch Left and Button A = d100
Select Switch Left and Button B = d20
Select Switch Right and Button A = d12
Select Switch Right and Button B = d6
You can hold down the Button and it will flash through many tosses.
Release the Button and your results will show on the Circuit Playground as
two (or one) lit NeoPixel
Red=Tens Place (0-9)
Blue=Ones Place (0-9)
Green=Tens and Ones are the same (00,11,22,33,44,55,66,77,88,99)
The NeoPixels are arranged from 0 - 9 . If you are holding your Circuit Playground with the USB port facing Up
0 is the top left NeoPixel closest to the USB port
1 is to the left of that
4 is the bottom let NeoPixel closest to the Battery Jack
5 is the bottom right NeoPixel closest to the Battery Jack
9 is the top tight NeoPixel closest to the USB port
let troll = 0
let tens = 0
let ones = 0
let switcher = 0
loops.forever(() => {
music.stopAllSounds()
if (input.buttonA.isPressed()) {
if (switcher) {
tossd12()
} else {
tossd100()
} else {
if (input.buttonB.isPressed()) {
if (switcher) {
tossd6()
} else {
tossd20()
input.onSwitchMoved(SwitchDirection.Left, () => {
switcher = 0
input.onSwitchMoved(SwitchDirection.Right, () => {
switcher = 1
function tossd100() {
troll = Math.random(99)
prepthrow(troll)
return
function tossd20() {
troll = (Math.random(20)) + 1
prepthrow(troll)
return
function tossd12() {
troll = Math.random(11) + 1
prepthrow(troll)
return
function tossd6() {
troll = Math.random(6) + 1
prepthrow(troll)
return
function showtoss(ones: number, tens: number) {
light.pixels.clear()
music.playTone((ones * 100) + 1, 50)
if (ones == tens) {
light.pixels.setPixelColor(tens, Colors.Green)
else {
light.pixels.setPixelColor(ones, Colors.Blue)
light.pixels.setPixelColor(tens, Colors.Red)
light.pixels.show()
return
function prepthrow(troll: number) {
ones = troll % 10
tens = troll / 10
showtoss(ones, tens)
return
