User Manual
Select the type of die you would like to throw by putting the Select Switch in the proper position and then pressing the proper Button
Select Switch + Left Button d100 (0-99) Right Button d20 (1-20)
Select Switch - Left Button d12 (1-12) Right Button d06 (1-6)
You can hold down the Button for as long as you want. Dance to the sound of the bones rolling.
Release the Button and your results will show on the Circuit Playground as two (or one) lit NeoPixels
Red=Tens Place (0-9)
Blue=Ones Place (0-9)
Green=Tens and Ones are the same (00,11,22,33,44,55,66,77,88,99)
The NeoPixels are arranged from 0 - 9 . If you are holding your Circuit Playground with the USB port facing Up
0 is the top left NeoPixel closest to the USB port
1 is to the left of that
4 is the bottom let NeoPixel closest to the Battery Jack
5 is the bottom right NeoPixel closest to the Battery Jack
9 is the top tight NeoPixel closest to the USB port
