Hackaday.io Hackaday.io
Sign up Log in
Experiments with Baremetal + Raspberry Pi
Learn-by-doing. Would like to get something like MicroPython on a Pi Zero
jonathan-beriJonathan Beri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
2 comments
1.6k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.9k
2
1.6k
2
Team (1)
  • jonathan-beriJonathan Beri
Join this project's team
Software
ongoing project
raspberry pi rpi pi zero pizero BAREMETAL micropython bare-metal RASPBERRY-PI pi-zero
This project was created on 08/16/2016 and last updated 3 years ago.
Description
I've been curious about baremetal programming on linux-class devices for awhile. Turns out there's a community of folks with the same curiosity (https://www.raspberrypi.org/forums/viewforum.php?f=72) and a lot of progress made in open source land. I'm plan to use this project as mostly a learning exercise. Since we all need a goal to get stuff done, I'm going to *try* to port MicroPython (https://github.com/micropython/micropython) onto a Raspberry Pi Zero. To the text editor!
Project Logs
Collapse
  • Blinky
    Jonathan Beri • 08/19/2016 at 14:05 • 0 comments
    Pretty straight-forward to blink the on-board LED. Code from https://github.com/dwelch67/raspberrypi/tree/master/boards/pizero/blinker01.
  • Prior Art
    Jonathan Beri • 08/16/2016 at 15:33 • 0 comments
    A search for "baremetal raspberry pi" will return a handful of results from a few brave souls. The most common are:
    • Bare Metal Programming in C
    • The official "Bare Metal" forum on raspberrypi.org
    • An active project from dwelch67
    In addition, there's a rather dated project that got ChibiOS (my preferred RTOS) running on a Pi using the above resources. There may be a separate project for the RTOS in the future!
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
deʃhipu wrote 05/29/2017 at 05:26 • point
Have you seen this port of MicroPython already? https://forum.micropython.org/viewtopic.php?f=12&t=3317
Jonathan Beri wrote 05/29/2017 at 12:28 • point
Oh, that's awesome!
Build a trimmed down, fast custom Linux distro for your next Raspberry Pi project.
Project Owner Contributor
Raspberry Pi - Buildroot
gamaralgamaral
The 2016 Hackaday Prize
Make Raspberry Pi Again
aryaArya
A little computer with Raspberry Pi 3 and the amazing PICO8, a fantasy console. Now it's real in your hands.
PICO8 Real Console
victor-barahonaVictor Barahona
Use a Raspberry Pi and a OLED screen to constantly output BTC/GBP rate
Bitcoin live stats using Raspberry Pi 3
ash-johnsonAsh Johnson
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Experiments with Baremetal + Raspberry Pi", please tell us the reason.
Send message
Remove Member
