Controlling an OWI arm with the joystick and microcontroller
08/25/2016 at 20:41 • 0 comments -
Report Descriptor
08/17/2016 at 13:38 • 0 commentsReport descriptor (packet) structure Byte.Bit Function Description 0.7 X7 analog value X LSB
0.6 X6 0.5 X5 0.4 X4 0.3 X3 0.2 X2 0.1 X1 0 X0 1.7 Y5 analog value Y LSB
1.6 Y4 1.5 Y3 1.4 Y2 1.3 Y1 1.2 Y0 1.1 X9 analog value X MSB
1 X8 2[4:7] H[1:4] hatswitch buttons 2.3 Y9 analog value Y MSB
2.2 Y8 2.1 Y7 2 Y6 3[0:7] Rz analog value yaw (rotation) 4[0:7] B[1:8] Buttons 1 to 8 5[0:7] T analog throttle 6[0:7] B[9:12] Buttons 9 to 12 http://processors.wiki.ti.com/index.php/Stellaris_USB_Host_Joystick
Build
08/17/2016 at 11:34 • 0 comments
**** Build of configuration Debug for project usb_host_joystick ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../startup_ccs.c'
'Invoking: ARM Compiler'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="startup_ccs.d" "../startup_ccs.c"
"../startup_ccs.c", line 236: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"../startup_ccs.c", line 254: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"../startup_ccs.c", line 272: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
'Finished building: ../startup_ccs.c'
'Building file: ../usb_host_joystick.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="usb_host_joystick.d" "../usb_host_joystick.c"
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 186: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 200: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 214: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 316: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"../usb_host_joystick.c", line 156: remark #1534-D: (ULP 7.1) Detected use of global variable "g_ui32NumHostClassDrivers" within one function "main". Recommend placing variable in the function locally
"../usb_host_joystick.c", line 164: remark #1534-D: (ULP 7.1) Detected use of global variable "g_psJoystick" within one function "main". Recommend placing variable in the function locally
"../usb_host_joystick.c", line 164: warning #552-D: variable "g_psJoystick" was set but never used
'Finished building: ../usb_host_joystick.c'
'Building file: C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl/drivers/pinout.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="drivers/pinout.d" --obj_directory="drivers" "C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl/drivers/pinout.c"
'Finished building: C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl/drivers/pinout.c'
'Building file: ../include/usbhhidjoystick.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="include/usbhhidjoystick.d" --obj_directory="include" "../include/usbhhidjoystick.c"
"../include/usbhhidjoystick.c", line 329: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"../include/usbhhidjoystick.c", line 330: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"../include/usbhhidjoystick.c", line 349: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"../include/usbhhidjoystick.c", line 350: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"../include/usbhhidjoystick.c", line 351: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"../include/usbhhidjoystick.c", line 107: remark #1534-D: (ULP 7.1) Detected use of global variable "g_sUSBHJoystick" within one function "USBHJoystickOpen". Recommend placing variable in the function locally
'Finished building: ../include/usbhhidjoystick.c'
'Building file: C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="utils/uartstdio.d" --obj_directory="utils" "C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c"
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c", line 668: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c", line 878: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c", line 1044: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c", line 1139: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c", line 134: remark #1534-D: (ULP 7.1) Detected use of global variable "g_pcHex" within one function "UARTvprintf". Recommend placing variable in the function locally
'Finished building: C:/ti/TivaWare_C_Series-2.1.2.111/utils/uartstdio.c'
'Building file: C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="utils/ustdlib.d" --obj_directory="utils" "C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c"
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 193: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 383: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 505: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 1625: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 1626: remark #2623-D: (ULP 5.4) Detected an assignment to a type with size less than int. To avoid unnecessary sign extension, use int-sized types for local varaibles and convert to smaller types for static storage.
"C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c", line 42: remark #1534-D: (ULP 7.1) Detected use of global variable "g_pcHex" within one function "uvsnprintf". Recommend placing variable in the function locally
'Finished building: C:/ti/TivaWare_C_Series-2.1.2.111/utils/ustdlib.c'
'Building target: usb_host_joystick.out'
'Invoking: ARM Linker'
"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual -z -m"usb_host_joystick_ccs.map" --heap_size=0 --stack_size=2048 -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --reread_libs --display_error_number --diag_wrap=off --warn_sections --xml_link_info="usb_host_joystick_linkInfo.xml" --rom_model -o "usb_host_joystick.out" "./startup_ccs.obj" "./usb_host_joystick.obj" "./drivers/pinout.obj" "./include/usbhhidjoystick.obj" "./utils/uartstdio.obj" "./utils/ustdlib.obj" "../usb_host_joystick_ccs.cmd" -llibc.a -l"c:/ti/TivaWare_C_Series-2.1.2.111/driverlib/ccs/Debug/driverlib.lib" -l"c:/ti/TivaWare_C_Series-2.1.2.111/usblib/ccs/Debug/usblib.lib"
<Linking>
remark #10371-D: (ULP 1.1) Detected no uses of low power mode state changing instructions
'Finished building target: usb_host_joystick.out'
"C:/ti/ccsv6/utils/tiobj2bin/tiobj2bin" "usb_host_joystick.out" "usb_host_joystick.bin" "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armofd" "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armhex" "C:/ti/ccsv6/utils/tiobj2bin/mkhex4bin"
**** Build Finished **** -
Output
08/17/2016 at 11:30 • 0 comments -
Created / Modified Files
08/17/2016 at 11:29 • 0 commentsusb_host_joystick.c
include/usbhhidjoystick.h
TivaWare_C_Series-2.1.2.111/usblib/host/usbhhid.h
