A project log for A 16-bit CPU in Logisim
A custom 16-bit CPU created in Logisim
Instruction Decoder
Great project, and I like the microcoded approach. By the looks of it this is "vertical" microcode as it is only 12-bits wide. Am I correct? How did you generate / write the microcode, is it published? (sorry if I missed it). Thanks!
Yes, delete it Cancel
