Instruction Decoder
A project log for A 16-bit CPU in Logisim
A custom 16-bit CPU created in Logisim
martianMartian • 05/13/2020 at 12:27•1 Comment
Instruction Decoder
zpekic wrote 01/02/2021 at 00:29 • point
Great project, and I like the microcoded approach. By the looks of it this is "vertical" microcode as it is only 12-bits wide. Am I correct? How did you generate / write the microcode, is it published? (sorry if I missed it). Thanks!
