I made a custom USB HUB and now free to everyone to download
You have discontinuity i.e. power/ground plane splits under your differential USB tracks. Might want to route those 4 vertical tracks else where.
Any thoughts about a Multi-TT version? Using this Single-TT chip is cheaper, but it means poor performance if more than one 12 Mbit/sec or 1.5 Mbit/sec devices attempt to communicate simultaneously.
I am not sure, I took one of the schematic on the internet and tried to reproduce on eagle + pcb.
I found out this chip was too complicated and I made another one. Check out my github
Hi, does the differential impedance matter in this case?
You need to be careful about the traces, they need to be same length. probably mine is not to top standard but working as usb 2.0
Do you have design files for this?
