1Step 1
Get the PCB from https://oshpark.com/shared_projects/QrjTnDg1
2Step 2
Populate the PCB -- solder the ATmega328p, the reset resistor (10kΩ), the I2C pullup resistors (10kΩ, optional), capacitor (10-1000µF, optional). Solder the pin headers for the servos and power, and an extra pin or wire for the reset.
3Step 3
Connect your ISP programmer to the 3v3, GND, MISO, MOSI, SCK and Reset pins as follows:
If you are making the 2ch version, the pin names are printed on the PCB. Get the source code from https://bitbucket.org/thesheep/d1mini-18ch-servo/src for the 18-channel version or https://bitbucket.org/thesheep/d1-mini-20ch-servo/src for the 20-channel version. To flash the 18-channel version, use Arduino IDE. To flash the 20-channel version, run "make flash" in the firmware directory.
4Step 4
After flashing, set the fuses with:
avrdude -c usbasp -p m328p -U lfuse:w:0xE2:m -U hfuse:w:0xDF:m
5Step 5
Your shield is ready to be used!
deʃhipu
