This system has an OS and language developed from scratch. I have tried to make both as simple as possible, while still being useful. The language (called MC) borrows heavily from C and Forth. It is easier to parse than C. It uses stack based semantics for expression evaluation and function call / return. The compiler does a few simple optimisations. The compiler source code is 2300 lines of C, I'm currently in the process of rewriting the compiler in MC so that I can compile programs on the 8051 system.
The OS has a flat file system and a simple shell that supports passing arguments to programs and input/output redirection. The OS is currently about 1300 lines of assembly language and 1000 lines of MC.
Regardless of any future developments and increases in complexity of the OS and language, I intend to always retain a minimalistic version, always less than 10000 lines of code.
Below is a photo showing examples of MC code.
Are you're using indentation for program structures?
