All building of the hardware of the robot has come to a halt because we are having difficulty getting the steel L channel delivered to our workshop. The L channel will be used to construct the lower most frame in which the drivetrain in to be located.
EDIT: the steel parts have come in from Vex, construction of the chassis is now underway.
