Hackaday.io Hackaday.io
Sign up Log in
Hacker's Beer
Have you ever tried to make your very own beer? No? And why not? And why not to automate that?
vojtech-vladykaVojtech Vladyka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
568
3
4
1
Team (2)
  • vojtech-vladykaVojtech Vladyka
  • kolmanmartinkolman.martin
Join this project's team
hardware
ongoing project
beer brewery automation
This project was created on 08/30/2016 and last updated 10 年前.
Project Logs
Collapse
  • First brew. Fully manual.
    Vojtech Vladyka • 09/21/2016 at 12:40 • 0 comments
    tried first test brew. Fully manual at 27l volume. It is supposed to be an IPA so we are waiting for results, because at this moment is fermented wort quite bitter. Hopefully laying at cellar for few days fixes that.
    Check out few pics from this here: https://pac.chapadla.cz/cloud/index.php/apps/gallery/s/72icOqgS4yXw0AL
View project log
Log In/Sign up to comment
Sign up with Github
OR
aldolo wrote 05/16/2021 at 03:45 • point
your link is dead. what about you after this experiment?
Vojtech Vladyka wrote 09/21/2016 at 15:31 • point
Thanks a lot for tips. We are aiming to 50l volumes, so getting big enough fermentation vessel is going little bit problem since we need to keep price low. But we will focus on that.
We want to automate at first step mixing and temperature control for brewing vessel. Next step will hopefully going to be automation of transfer between vessels and last step is going to be automation of cooling. At this moment we are planning to keep manual adding of resources and everything after cooling phase.
ML wrote 09/21/2016 at 14:50 • point
What parts of the process are you planning to automate?
I highly recommend upgrading to glass for your fermentation vessels.  Polymer / bucket type fermenting setups are quite porous and no matter how much you try to sanitize your equipment, it absorbs / retains material from the previous batch.  Sometimes this results in slight flavor variations in your beer, but in some cases it can result in a ruined batch of beer.
A full open source electronic lab
Project Owner Contributor
Yellow pitaya
sanpiSanpi
A simple test stand for a 1960`s motorcycle crankshaft.
Crankshaft Teststand
heinz-peter-liechteneckerHeinz-Peter Liechtenecker
Vaguely based off of the exoskeleton from Elysium
Pneumatic Exoskeleton
james-hobsonJames Hobson
A western themed work in process automaton.
Howdy!
greg-zumwaltGreg Zumwalt
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Hacker's Beer", please tell us the reason.
Send message
Remove Member
