Arduino Precision Time
Most people uses the Time Library With DS3231 or gps time.. Why we synchronize Time in intervals instead reading the integrated TCX0 or PPS
Whats the Difference?
The Library counts the internal "Time Library" Seconds with PPS(PulsPerSecond) from DS3231 or GPS.
That means the Original Time Library calculate the theoretical time from SystemMillis affected by Clock Accuracy.
It Adds a free to choose Interrupt to update Seconds from GPS-PPS or DS3231 1Hz Squarewave.
The Theory 1, GPS Based PPS Signal accuracy, long time compensated 30ns Drift
The Theory 2, DS3231 TCXO, Temperature compensated Crystal, 1-3ppm Longtime Drift.
The Theory 3, Millis aligned between two PPS Signals and synchronized with 32768hz or internal clock for same accuracy as Theory1/2.
3 chooseable Timers to count Millis synced to PPS(PulsPerSecond).
3 chooseable Inputs to count Timers, T0,T1, internal Clock
(Arduino Reserved T0,choose with my T2 Millis Arduino variant to switch Timer0 and Timer2 in Core)
3 chooseable Interrupts, ICP1,INT0,INT1, or own event with ResetTimer() Function for PPS
Calibration function to calibrate Millis Factor to precise timing maybe 15.9599999 Crystal precision.
So we can measure over hours in Millisecond Precision with round about 32768Hz 1-2ppm.
  • 1
    Step 1
    To choose the Timer edit Time.ccp Line to Timer number:
    Example Timer 1:
    ```#Define TIMERVAR 1```
    Same to Reserve Pin D8 for ICP1:
    ```#Define Pin8 1```
  • 2
    Step 2
    Codeexample:
    Setup():
    initTimer(2,0,2); //Standard Settings init (Timer2, Internal clock,INT0(Pin2) DS3231 SQWPin 1Hz->INT0
    Loop() Overwiew:
    CalibrateNow();
    Serial.println("New Calculation Frequency for PrecMillis()");
    Serial.println(recalculateF_CPU());
    Serial.println(precmillis());
    Serial.println( myprecmillis - mymillis - sync);
    Output: (Good Measurement, The Millis from Core Drifts 2-4ms/Second) The Real Delay(1000) maybe ca. 1060ms
    11993117
    14591
    39
    15658
    42
    16725
    45
    17793
    50
    18860
    55
    19927
    58
    20995
    63
    22061
    65
    23129
    71
    24196
    75
    25263
View all instructions
nodemcu12ecanada wrote 10/29/2025 at 20:55 • point
If your microcontroller has WiFi I would recommend getting the exact time from the internet. Corrected for daylight saving time or not. No RTC or battery needed. The time from a RTC drifts a few seconds a month. Internet time does not.
Project is here: https://hackaday.io/project/174577-free-highly-accurate-time-and-date-from-internet
I use NodeMCU/esp8266 for WiFi functions but have ordered an Arduino Nano ESP32 for future projects.
