1Step 1
To choose the Timer edit Time.ccp Line to Timer number:
Example Timer 1:
```#Define TIMERVAR 1```
Same to Reserve Pin D8 for ICP1:
```#Define Pin8 1```
2Step 2
Codeexample:
Setup():
initTimer(2,0,2); //Standard Settings init (Timer2, Internal clock,INT0(Pin2) DS3231 SQWPin 1Hz->INT0
Loop() Overwiew:
CalibrateNow();
Serial.println("New Calculation Frequency for PrecMillis()");
Serial.println(recalculateF_CPU());
Serial.println(precmillis());
Serial.println( myprecmillis - mymillis - sync);
Output: (Good Measurement, The Millis from Core Drifts 2-4ms/Second) The Real Delay(1000) maybe ca. 1060ms
11993117
14591
39
15658
42
16725
45
17793
50
18860
55
19927
58
20995
63
22061
65
23129
71
24196
75
25263
