Die-CRASH
Die-CRASH intends to save the life of people using NI technology. This can simulate the traffic at junctions where the violation of signals.
The main idea of Die-CRASH is to avoid road accidents and to analyze the risk factors for road traffic injuries. Collision occurs when two or more bodies exert forces on each other for relatively short time. Traffic collision results in injury, death and property damage. So, there is a need of sophisticated traffic communication system that alerts the driver to change the directions on the road. Implementation of this system is likely to reduce the damage occurred by a collision.
Problem Solving:
• When the vehicle and the obstacle are moving in the same or else in the opposite direction and if the distance between them is below the threshold provided, based on speed of vehicle the person will be alerted. If the person doesn’t respond, then brakes will be applied automatically.
• When the vehicle tries to move into the other lane either to left (right), if the obstacle is detected very near to the vehicle, then the brakes of right (left) wheels are applied to av
  • 1 × myrio microprossesor
  • 1 × ultravoilet sensors to detect object
  • 1 × vibrator
  • 1 × automatic braking system
