got on show & tell!
Demo loops and interactive games and displays made with Arduino Uno and Mega Controlling 32x32, 32x64 and 64x64 RGB Matrix panels
got on show & tell!
in an effort to convey as much information on the small number of pixels available, I had designed a small number bitmap set, I have since expanded this into a full alphabet (Ascii 32 - 126)
this font is proportionately spaced, and as narrow as possible and only 6 pixels high with descenders. the bitmap table is under 256 bytes with a offset and width table taking up another 180 . these tables could be eliminated, but I want fast as possible performance without having to create a table in RAM.
Also have a working Tetris and Brick-Out now, and human control is working on 3 of 4 games.
Time from an ESP8266 is working, as is weather, but displaying the weather forecast without the micro font was not practical.
I had waited long enough, and a complete code rewrite from procedural flat C to OO C++ model.
Advantages of OO redesign:
*Memory Management: Due to the constraints of up to 64x64 RGB pixels on an arduino Mega, memory management had been key in the original implementation of the code. Moving the code to OO C++ would normally mean leaving even more of the memory in the hands of the compiler, but inorder to force reuse of the pool of available RAM, I wrote my own memory management routines, and each Mode or Module that runs on the device can clear out and use as required this same buffer of ram, that only has to be allocated once. Previous versions of the code had approached maximum allocation, forcing reuse of global variables such that adding one more 8Bit int could cause the code to no longer execute.
Ok, I'm impressed that you did that much with underpowered CPUs like nano and mega.
If you'd like to do more though with more recent CPUs (teensy and ESP32), I'm sure you've heard about SmartMatrix.
You can find SmartMatrix::GFX and some examples with Teensy and ESP32 here:
http://marc.merlins.org/perso/arduino/post_2019-04-01_SmartMatrix_-SmartMatrix-Shield-v4-for-Teensy_-ESP32-shield-with-level-shifter_-and-SmartMatrix_GFX.html
Library: https://github.com/marcmerlin/SmartMatrix_GFX
