1Step 1
Lots to say here, but not done yet.
Very briefly:
+ 3D print plastic pieces
+ load program to WiFi boards (EPS8266) for steppers
+ fit BYJ28 stepper motors and wire up the ULN2003 driver boards + WiFi
+ attach 3 motor blocks to walls (or other high supports)
+ make the effector (for test, 60ml syringe extruder)
+ program GCODE interpreter and WiFi access point; fit to effector
+ run strings from effector to each motor block
+ program hand controller and WiFi
+ use hand controller to calibrate and test RB3DP
+ feed GCODE file of object to WiFi access point (either direct from laptop running Cura, or plugging in an SD card to effector or hand controller)
RigTig
