The SQ11 can be disassembled by taking off the multicolour strip, then removing the tiny Philips screw.
I de-soldered the Li-po battery, soldered positive and negative leads to a (totally overkill) 18650 protection circuit.
I then verified that this quick hack still recorded video and charged the battery (very slowly, as the SQ11 motherboard is tailored for the 200mAh battery). As the 18650 is fully removable, I can fast-charge it in another contraption if I want.
Finally I got through 15 iterations for the 3D printed case, discovering the hull command in OpenSCAD and taking full advantage of it.
Unfortunately I discovered that there are multiple version of the SQ11 with different camera mount and heat spreader, so if you buy one, I can't guarantee that my case will fit unmodified.
Neal D Corbett
MS-BOSS
lion mclionhead
Hi !
Did anyone else here buy SQ11 (fake..Version unknown..) that was supplyed with USB-cable which DO NOT HAVE the AV-plug in it ? the Yellow (rca) video plug to be connected into TV/tft etc.
If someone knows the PinOut how to DIY-make the cable, please let me know. i have spare cables from other "digital photo cameras" which could be matched together if only i knew the Pinout.
i have gathered RCA and USB pinout info from web, etc, but i wonder if SQ11 uses Standard figuration for PinOut's...
Done diy cables in past etc Devices, not a total nooby.
i bought my SQ11 from Aliexprs during Xmas 2023 , when it was on sale for like 3euro's.
cagiva4ever( )yah00 dot c0 m
