Currently using an I2C 16x2 display which is overkill and too big, going to switch to 7 segment LED x 2 I think plus shift register(s).
Currently using a mini pot for temperature set, may switch to +/- buttons.
Currently have no relay connected, just a piezo beeper when water reaches correct temp.
First used High-low tech method for programming ATtiny, but switched to arduino-tiny cores in order to gain tone() support for my piezo. I think the arduino-tiny cores seem to work a little better anyway, although it's SLIGHTLY more work to install them.
I'm using an Arduino UNO to program ATtinys right now using a custom "shield" (some pins and wires soldered to a socket and a glob of hot glue) according to the diagrams at high-low tech.
Currently powered by rechargeable USB li-po battery/power supply... going to include a 5v switching power supply from a half-broken phone charger hidden in the case.
Ideally, in the end, I will plug this unit into the wall, plug the kettle into this, and dip the thermometer into the water. Everything will be contained in as small a package as possible. Probably will cost more than a proper temp-controlled kettle but I travel a bunch and drink tea that needs the water to be ~75*C. Plus this is a fun way to learn to push the ATtiny for small embedded projects.
I'll post updated code and pictures evenetually, or sooner if someone requests it!
At this stage the whole unit is a backpack on the relay with leads out to the tiny 2-digit display. Nice and super tiny, it's very satisfying.
