Hi guys,
Just wanted to show you what the project is looking like at the moment. Any questions / advice / things you want to see in this project, just leave a comment and we will be grateful for your feedback. One of the big things was making sure that this worked using any operating system on the Raspberry Pi and by designing it to use the RCA output, once this is built, it should be able to plug into any Raspberry Pi and work instantly so this can be easily combined with any other project.
danielmcgraw
