command line ffmpeg/mplayer wrapper program
07/03/2020 at 20:48 • 0 commentsLions originally wanted everything to have a GUI. In old age, lions just want as much computing power devoted to the task as possible instead of the interface. After writing a video editor, lions have accumulated many usages of ffmpeg & mplayer from the command line. The mane use of mplayer is extracting decompressed audio.
mplayer -ao pcm:file=audio.wav -vc null -vo null
But specifying the output file doesn't work. ffmpeg has a usage which extracts decompressed audio, but this works for fewer sources.
ffmpeg -i <input file> -vn <output file.wav>
Then there's extracting the audio from a movie without any transcoding.
ffmpeg -i <input file> -vn -acodec copy <output file>.mp4
Extract the video from a movie without any transcoding:
ffmpeg -i <input file> -an -vcodec copy <output file>.mp4
The other thing lions use ffmpeg for is transcoding video from a variable framerate to a fixed framerate file. This degrades the quality, but if the specified bitrate is higher than the input bitrate, it'll encode as high as the input bitrate.
ffmpeg -i <input file> -c:v mpeg4 -vb 5000k -an <output file>
Lions use ffmpeg to encode from an uncompressed source, for debugging machine vision programs. This isn't as fast as linking ffmpeg & calling the functions with a memory resident frame buffer but it's simple.
ffmpeg -y -f rawvideo -y -pix_fmt bgr24 -r 15 -s:v <width>x<height> -i - -c:v mpeg4 -vb 5000k -an <output file>
It would be a lot simpler if these most common ffmpeg usages were condensed into yet another wrapper program.
Command line frequency counter
06/17/2020 at 23:11 • 0 commentsSome sample waveforms show 2 surface mount 32.768 crystals running at 32766 & a 3rd through hole crystal at 32768. They can also be affected by the probing method. As lions discovered from creating Heroineclock II, crystals can vary by a lot. .01% precision for a resistor is high precision, but for a crystal is way out.
It gives the standard deviation of the wavelength in samples, useful for knowing how stable the signal is. In the sample data, the through hole appears much more stable than the surface mount, but the standard deviation also depends on the samplerate. Frequency is not as affected by samplerate as the standard deviation. The surface mount standard deviation drops to 20 when sampled at 100 megsample.
Best results have come from counting zero crossings with a debounce delay, rather than counting peaks & troughs with hysteresis. The best debounce depends on how noisy the signal is. The zero crossings are where the waveform is steepest, so the time of the zero crossing can be known to the most precision. Slight errors in where each cycle begins can create huge errors in the frequency measurement & the standard deviation.
Of course, to just see if 2 crystals are way off, load them in an audio editor & play them back.
Automated packing
06/12/2020 at 18:11 • 0 commentsDreamed about software being used to determine the most efficient way to pack items into boxes. It was based on either analyzing video of the products or 3D scanning everything that entered the warehouse. Amazon.com was using it in fulfillment centers. All the humans did was move items from the shelf to a box the computer selected & where in the box the computer said to put them.
Lions don't believe any such system exists. Workers currently pick the box by eye & pack it by eye. Random variations in packaging might make it impractical to prescan items when they enter the warehouse, so workers would need to scan the dimensions of every item in an order, then the computer would pick the box.
Making the scanning process fast & transparent would be a good machine vision problem.
Web based file manager for Android
06/11/2020 at 03:41 • 1 commentThen, there was this craptastic program. The lion kingdom long dreamed of a way to manage a phone's filesystem in a browser instead of ADB, to download & upload files without ADB.
After many years, the desire finally hit critical mass, there was enough time without commuting, & the deed was done. It's 25 year old HTML, no javascript, no AJAX, no jquery, no node.js, no react.js, no angular.js, & would never get a job, but it does the job. There's no security. It's fast when it works & easy to manetain, like all web applications 25 years ago.
A key difference with past lion programs is this one doesn't run in the background. Once it's cleared from the app manager, the server is gone.
There are a few limitations.
It can't create symbolic links, since lions have never needed a symbolic link on a phone.
The phone has to be rebooted occasionally, as Android has memory leaks which cause the network performance to get slower & slower.
It can't write to external storage. Android has dropped any support for writing to an SD card from a user program. It can only read.
There was originally a desire to sort by size & date, but the kind of file operations lions have done so far have been too simple to justify it.
https://github.com/heroineworshiper/webphone
11/15/24
It grew quite a bit since 2020, gaining an edit function, sorting. The next frontier is a dual copy function. 1 copy function would copy the selected files to the same directory with different names. Another copy function would copy the selected files to another directory.
How fast is a pipe?
06/03/2020 at 19:29 • 0 commentsAt least on the lion kingdom's obsolete 4Ghz 8 core Ryzen, it's
% ./random |catbps main 33: 1154458213 bits/sec main 33: 1155342065 bits/sec main 33: 1158795636 bits/sec main 33: 1161013450 bits/sec main 33: 1153026045 bits/sec main 33: 960231704 bits/sec main 33: 1077391216 bits/sec
From a phone through ADB, it's
% adb shell /data/random | catbps main 33: 9080670 bits/sec main 33: 5169716 bits/sec main 33: 4291419 bits/sec main 33: 4482882 bits/sec main 33: 8428983 bits/sec main 33: 8613113 bits/sec main 33: 9701913 bits/sec
Native linux on a laptop to ethernet:
root@heroine:/root% netcat -l -p 1234 | catbps main 41: 1309 bits/sec total_bytes=1024 main 41: 939087920 bits/sec total_bytes=117504400 main 41: 940861506 bits/sec total_bytes=235229696 main 41: 941440127 bits/sec total_bytes=353027392 main 41: 941604955 bits/sec total_bytes=470845712 main 41: 941564611 bits/sec total_bytes=588658984 main 41: 941590569 bits/sec total_bytes=706475504 main 41: 941602141 bits/sec total_bytes=824293472 main 41: 941494025 bits/sec total_bytes=942097912 main 41: 941467236 bits/sec total_bytes=1059899000
Linux on a virtual machine to ethernet:
root@heroine:/root% netcat -l -p 1234 | catbps main 41: 5333 bits/sec total_bytes=1024 main 41: 14750500 bits/sec total_bytes=1850368 main 41: 16163477 bits/sec total_bytes=3876864 main 41: 10647144 bits/sec total_bytes=5209088 main 41: 9818954 bits/sec total_bytes=6438912 main 41: 10589858 bits/sec total_bytes=7763968 main 41: 22450331 bits/sec total_bytes=10575872 main 41: 12099960 bits/sec total_bytes=12091392 main 41: 15158875 bits/sec total_bytes=13991936 main 41: 15942073 bits/sec total_bytes=15986688 main 41: 14217453 bits/sec total_bytes=17767424
The random program just prints random ASCII characters as fast as possible. Recognizing that the rand function has a finite speed, it precalculates a fixed buffer & resend it.
Obviously, adb doesn't do any compression. The catbps program just measures how fast data is coming from stdin but doesn't write it to stdout. These are basic needs lions have had for a while. Next comes hacking ADB to improve this bandwidth. You can't hack the ADB server on a normal phone, but this is a special phone.https://cdn.hackaday.io/files/1380505906331200/catbps.c
https://cdn.hackaday.io/files/1380505906331200/random.c
We all want to know how fast our networks are, so these programs can be run with netcat.
netcat -l -p 1234 | catbpsrandom | netcat 10.0.0.14 1234
Delete all IPC objects
05/30/2020 at 22:51 • 0 commentsManagement of the audio interface is notoriously bad in Goog Chrome, so we've all adopted the same ritual in the 15 years since the Goog's IPO.
killall -9 google-chrome-stable chrome chrome-sandbox
Then, you have to run ipcs & ipcrm to delete all the IPC objects it leaves behind, one by one. Goog employees don't know how to properly delete shared memory when their programs crash. For those of us not completely focused on passing interview questions with leetcoding, the secret is to call
shmctl(shmid, IPC_RMID, 0);
right after calling
shmat(shmid, NULL, 0);
But anyways, it was finally time to automate this process.
https://cdn.hackaday.io/files/1380505906331200/ipcclean.c
This program just deletes every IPC object. It has to be run as root.
Download a segmented video file
05/30/2020 at 04:23 • 0 commentsIt's a problem we've all come to know in the last 10 years. We want to download a video from a site other than the goo tubes, so we start up the network panel in Chrome & load the page. Then, we look for the largest files being downloaded & files ending in .ts, .mp4, or .webm. The problem is, it downloads a bunch of small files containing a number like 00002.
It's a pain in the ass segmented video. The trick is finding the 1st & last segment numbers. Seek to the end of the video to get the last segment number. Seek to the start of the video to get the 1st segment number. After being stymied by these files for years, the lion kingdom finally decided to automate the process with a dead simple program.https://cdn.hackaday.io/files/1380505906331200/segments.c
It just searches the URL for the starting number & replaces that block of text with every number until the ending number. If the result is a stream format like .ts, the files can all be concatenated. If it's a .mp4, the files have to be loaded into an editor. Currently, it downloads base 10 numbers. It could be hacked to download hex numbers.
While it works for some PBS videos & some local TV stations, it doesn't work for discovery channel. They use some kind of encryption.
Transfer files using UDP
05/22/2020 at 23:10 • 0 commentshttps://cdn.hackaday.io/files/1380505906331200/udptest2.c
This program began life many years ago when the lion kingdom was trying to speed up ethernet by using UDP instead of TCP. Lions quickly realized this was useless, so it became manely a way of testing UDP connections through large file transfers. It also works with IPV6, but lions only tested it with numeric IPV6 addresses.
The general idea is it sends a certain number of packets at a time & waits for an ACK. There's no windowing or asychronous communication. It's useful for half duplex like radios. It uses the same port for receiving on the source & destination. This was necessary to get around a certain firewall. The packet size is hard coded.
The journey begins by starting the receiver on the destination.
udptest -6 -r 1234
This waits for connections on IPV6, all interfaces, port 1234. Then the transmitter starts on the source.
udptest -6 2017:0000:0000:0000:7690:5000:0000:0001 1234 file.txt
This sends a file over IPV6. By default, it sends 1 packet & waits for an ACK. Leave out the -6 to use IPV4.
udptest -r 1234
udptest 10.0.0.14 1234 file.txt
To increase the number of packets per ACK, provide the -n option to the receiver.udptest -r -n 8 1234
Use an EOS RP as a webcam on Linux
05/14/2020 at 00:54 • 0 commentsThis only works with the very latest cameras, manely the EOS RP. The journey begins by compiling the v4l2 loopback device.
https://github.com/umlaeute/v4l2loopback
insmod v4l2loopback.ko
This creates a new /dev/video device which can be simultaneously written & read. The same device is used for writing & reading.
Then, with the camera turned on, run
gphoto2 --stdout --capture-movie | ffmpeg -i - -vcodec rawvideo -pix_fmt rgb24 -threads 0 -f v4l2 /dev/video1
Take note of the frame size. The same frame size must be used for capturing.
Then, in the case of Cinelerra, recording must be configured to use uncompressed RGB, Video4Linux2, /dev/video1, 960x640, 15fps, frames to buffer in device: 2. If the framerate is too high, it'll studder. If it's too low, it'll studder less but be bearable. The kernel driver has a bug in its double buffering, as most double buffering newbies tend to have.Who knows what settings will get invoked with browser based video conferencing. An ideal video conferencing system would have gphoto2 send frames to a program that performed some realtime effects, defishing, sharpening, color correction.
ffmpeg can perform defishing with some convoluted command line parameters.
-vf "lenscorrection=cx=0.5:cy=0.5:k1=-0.1:k2=-0.1"
It uses nearest neighbor scaling & looks absolutely horrid. 1 of the lion kingdom's 2 computers only captures video with the camera in still photo mode. Another captures video with the camera in video mode. It's either a gphoto2 version problem or a USB problem. In still photo mode, the autofocus is disabled.
After a while, the lion kingdom decided the EOS RP wasn't worth the trouble & went back to an old fashioned webcam for video conferencing. -
Parse an IPV6 address
05/10/2020 at 07:43 • 0 commentsIPV6 has been everywhere & nowhere for 20 years now, but for the lion kingdom's day jobs, it's already everywhere. The problem is the shortpaw notation for the 16 byte addresses is a disaster. After using it for a long time, lions have only started to intuitively recognize the :: to mean stuff with 0's until the left & right side of the :: are justified. /128 represents the number of most significant bits comprising the subnet mask.
Despite some intuition, lions never type even the shortpaw notation but copy & paste all the addresses, so they might as well all be 8 hex numbers. If IPV6 ever becomes manestream, most animals are going to write the addresses as 8 16 bit hex numbers. The decision was made to provide a utility for converting the shortpaw notation to a full address.This is most useful for writing IPV6 software. Linux has the getaddrinfo function which accepts shortpaw notated IPV6 addresses, but lions most often have to program embedded systems which require a full 16 byte address.
https://cdn.hackaday.io/files/1380505906331200/parseipv6.c
Let's parse some addresses.
% ./parseipv6 2017::7690:5000:0:2/64
2017:0000:0000:0000:7690:5000:0000:0002 prefix=64
2017:0000:0000:0000:0000:0000:0000:0000 prefix=128
% ./parseipv6 ::ffff:0:0:0/96
0000:0000:0000:0000:ffff:0000:0000:0000 prefix=96./parseipv6 2600:1:9a28:46f3:0:35:f8b4:f601/64
2600:0001:9a28:46f3:0000:0035:f8b4:f601 prefix=64Despite so many decades of being just around the corner & supposedly allowing every device to have a fixed address, IPV6 addresses are still being assigned dynamically like the good old days.
