Basically the Beer Butlers home place will be the charge base, so it is important it still flawlessly docks. After some tinkering when I started sending commands to the roomba through the serial port, I was able to get it to dock at anytime. The body and compressor of the Beer Butler sit on top of this base. It really is that simple!
So we need to make sure we give the compressor the same load as when it was in the fridge. I pulled out the evaporator ( the cold part) and carefully traced the path and measured to find how long the evaporate coil needs to be.
The small end on the evaporator is a restriction to keep pressure up, once it pushed through this capillary it passes through the dryer and then the condenser again to repeat the process.
I simple make the copper tubing the same length as the factory made their path to maintain the level of efficiency that the factory intended. Hmm I think I voided the warranty.
Alright time to test! I need to make sure the fridge works well or using the parts for the robot are pointless. First thing I noticed from visual inspection is there is no external radiator... Hmm maybe it's inside? Maybe it's small enough it doesn't need one. Anyways I'm running it for 20 minutes and one hour marks to measure temperature.
Before applying power to the compressor
At 20 minute check in, the realistic time people want to have their beverages! We are down to 41 degrees.
1 hour mark, Boom! Super cold beer! 26 degrees. Of course, I will adjust the thermostat but it is analog so there is no markings for what temp it shuts the compressor off. I will likely stop it at 36 degrees.
Very cool idea.... The process of joining the metal pieces is called swaging, not swagging.
