The plastic disk will now fit in side no problem and does not move around. Next we need to machine the plastic so air can flow through and cool our beverages!
The outside edges are going well. I am doing these by hang because I do not have a drill press.
A little closer, almost there.... my hands hurt. If you do this, buy a drill press.
It is TIME TO TEST FIT !
Boom! everything fits and the heat sink is in place with the fan. All is fitting well.
Test fit a wine bottle inside :)
