Since I bought my Peltier element and heat sinks from the auction I wanted to make sure it worked. I powered it up without fans. It took about 2 minutes for the hotside to warm up. It appears it will work but I'm still considering buying a higher power Peltier. This one is a 45w to 50 watt.
Josh Starnes
