[ADIOS] Grove digital light sensor
04/16/2018 at 18:31 • 0 commentsBuy
http://www.seeedstudio.com/depot/Grove-Digital-Light-Sensor-p-1281.html
Wiki
http://www.seeedstudio.com/wiki/Grove_-_Digital_Light_Sensor
C++ library
https://github.com/Seeed-Studio/Grove_Digital_Light_Sensor
Hardware
Left part cutted and socket removed
5V 3.3V Gnd Gnd SCL Trinket A5 (Analog 5 => SCL, 3.3 kOhms hardware pull-up added) SDA Trinket A4 (Analog 4 => SDA, 3.3 kOhms hardware pull-up added) Arduino code
#include <Wire.h> #include <Digital_Light_TSL2561.h> void setup(void) { Wire.begin(); TSL2561.init(); } void loop(void) { display.println(TSL2561.readVisibleLux()); }
[ADIOS] Grove barometer
04/16/2018 at 18:27 • 0 commentsBuy
http://www.seeedstudio.com/depot/Grove-Barometer-Sensor-p-1199.htmlWiki
http://www.seeedstudio.com/wiki/Grove_-_Barometer_SensorC++ library
http://www.seeedstudio.com/wiki/File:Barometer_Sensor.zipHardware
Vcc 3.3 V Gnd Gnd SCL Trinket A5 (Analog 5 => SCL, 3.3 kOhms hardware pull-up added) SDA Trinket A4 (Analog 4 => SDA, 3.3 kOhms hardware pull-up added) Arduino code
#include "Barometer.h" #include static float baroTempVal; static float pressureVal; static float altitudeVal; Barometer baro; void setup(void) { baro.init(); } void loop(void) { baroTempVal = baro.bmp085GetTemperature(baro.bmp085ReadUT()); pressureVal = baro.bmp085GetPressure(baro.bmp085ReadUP()); altitudeVal = baro.calcAltitude(pressureVal); delay(1000); }
