This is a small sample of how you could use it.
And this is the code done in the arduino ide :
#define echo 8
#define trig 7
long duration,distance;
void setup() {
Serial.begin(9600);
pinMode(echo,INPUT);
pinMode(trig,OUTPUT);
pinMode(5,OUTPUT);
void loop() {
digitalWrite(trig,LOW);
delayMicroseconds(2);
digitalWrite(trig,HIGH);
delayMicroseconds(10);
duration=pulseIn(echo,HIGH);
distance=(duration/(2*29));
if(distance>=500 || distance<=0){
Serial.println("____");
else{
Serial.print(distance);
Serial.println("cm.");
digitalWrite(5,LOW);
if(distance<=45 && distance>=1){// distance in which the bracelet vibrates, you can edit according to your need
digitalWrite(5,HIGH);
Serial.println("Alarm!!!");
delay(400);
ElectronicABC
ken.do
ActualDragon
