With at least 2 minutes of data retention, the requirements for the refresh cycles don't look too bad.
Yet, with a "worst/best case" of 512 words to refresh every 2 minutes, or 120 seconds, that's 4 words to refresh every second. With an optimistic rate of 12 instructions per second, every third cycle will be stolen by the refresh cycles. That's a LOT and my idea to use an interrupt is now unrealistic. I can already forget about the scratch memory area, which would consume circuits anyway.
Now let's suppose I could "steal" one computing cycle every 4 or 8 cycle. The aim is to reuse as much existing circuits as possible to avoid bloating the architecture. Relays are cheap but not free.
The refresh occurs with a single instruction : increment an address register. The result goes back to the register and to the address bus, which triggers a read-and-rewrite cycle. This single instruction can be hardwired and injected in the instruction stream periodically, using a different "mode".
A "shadow A0" register can be implemented (3 relays, no need to decode 2 operands) and selected in the "refresh" mode. The increment instruction is selected automatically, "clear 2nd operand in ROP2 and set carry-in to 1 then add".
Another solution is to "steal" memory cycles, when no write to the memory is detected, so it occurs in the background, transparently. The address is generated by a LFSR, of a width that is equal to the address bus, +1 to prevent the "blind address 0" problem. Cost : maybe a bit less, this requires another MUX on the address bus, but the LFSR is not as wide as the whole system. 512 words will require 10 bits and 9 MUX (plus a little bit of detection logic to enable the address increment).
So this is another occurence today where the solutions come when I write about them :-D
The cycle-stealing idea is probably a bit sophisticated but it doesn't cripple the already poor performance. And it boils down to
- detect when no write to A0 or A1 might take place (it's not important if the instruction inhibits the write)
- create a suitable LFSR with a minimal amount of gates
The first is easy : detect when the instruction does not contain A0/D0 or A1/D1 in the destination register. It's as simple as checking 1 bit (the MSB) in the instruction "destination register" field.
The second part is a bit more heavy, as it requires significantly more relays. But it's an interesting exercise.
So we're going to make a LFSR with relays.
Let's start with the polynomials: I have written an article about them in 2009 so I have a list of minimal-XOR polynomials of relevant sizes. Look at some source code at http://ygdes.com/GHDL/lfsr4/ : there are a few polynomials that require only a XOR2 :-)
2=>1 3=>2 4=>3 5=>3 6=>5 7=>6 9=>5 10=>7 11=>9
So all that's left to implement is : a 2-inputs XOR and DFF latches.
I suppose I could reach 512 words (2^9) so the 11-tap polynomial looks good, since it will "skip" address 0 only once every 4 full cycles. Or we can just say "address 0 is the PC" and stick to a 9-tap LFSR (ensuring that the whole range is covered once and only once every 511 cycles).
The LFSR should not be 0 : 1s can be injected during the power-up sequence, or some relays could be set to power up in a set state.
Update: even-sized polynomials are preferred...
