After redesigning the frame to be made entirely of 1/4” aluminium, I sent the CAD files through to my friend. Not long after that I received a very heavy delivery from him. All up it probably weighed about 12kg.
This thing is huge!
I had to somehow drill holes into the edge of the top and
bottom plates. I decided that three M3
bolts per joint would be sufficient. My
friend was able to mark pilot holes in the side plates so drilling them was
straight forward. I placed them together
in a bench vice and used the side frame to mark holes in the top/base. The holes were then very carefully drilled
using a drill press. I still managed to
snap off two drill bits in the new holes.
Luckily they were both on the same edge so I was able to designate this
as the “back” tower.
Drilling holes in Dad's workshop
Careful tapping of the M3 threads
I may have snapped off drill bits in some holes and had to re-drill just next to them.
A very straight, strong and stiff frame.
As expected, when the grooves were slotted together, the
frame pulled true. I was very happy with
the rigidity and strength. It easily
supported my full weight sitting on top and didn’t flex at all.
