"Graphic card" complete !
12/03/2016 at 11:30 • 0 commentsAfter almost a week of investigation with the help of Spencer and Filippo, I was able to find my problem (bad bootcode.bin and start.elf files).
My "graphic card" is now working and I finally have a "standalone" RC2014 that I can connect it to my screen and to an USB keyboard.
Bye bye minicom :-)
Adding a graphic card
12/02/2016 at 08:44 • 0 commentsI would like to add the "Pi Zero Serial Terminal for RC2014" [1] to my RC2014 but encountered some problems about it [2]. I’m still investigating the issue with the help of Spencer and Filippo.
[1] https://www.tindie.com/products/Semachthemonkey/raspberry-pi-zero-serial-terminal-for-rc2014/
[2] https://groups.google.com/forum/#!topic/rc2014-z80/mtnZS_OWrmk
Planning to add a graphic card
10/02/2016 at 08:12 • 0 commentsI ordered parts to build a Pi Zero Serial Terminal, which act like a graphic card, providing a HDMI or composite output and USB port to connect an USB keyboard.
Minicom
09/20/2016 at 13:24 • 0 commentsIf you’re using minicom, set "Hardware Flow Control" to "No", to fix minicom offline status.
