Where can I ask for help with building & sourcing components?
The best place is on the SpritesMind forum.
Can I manufacture these and sell them?
Yes, of course you can. And no, I don't want any royalties. I only ask that you abide by the spirit of the copyleft licensing: you can make whatever proprietary modifications you like to your own personal UMDK carts, but if you give/sell a modded cart to someone else, you must provide them with all the source code modifications you've used so they can build upon your work, as you have built upon mine. Furthermore, you must grant them the freedom to use, replicate, modify and redistribute your work under the same terms.
How does the debugger work?
The debugger uses the GDB remote serial protocol, which is just a small set of commands like:
- Read 16 bytes of target memory at address 0x654321
- Set register D7 to 0xCAFEBABE
- Set target breakpoint at 0x123456
- Continue target execution
Originally
the remote serial protocol was designed to work over a serial (RS-232)
link, but it can also be made to work over TCP/IP, which is what I did.
So I wrote the gdb-bridge (actually "gdb-proxy" would have been a better name),
which listens for incoming GDB session connections on a TCP/IP port,
and when the connection arrives it waits for GDB to issue commands. Some commands can be executed directly by just reading
& writing the SDRAM[1], whereas others require a message-based conversation with the monitor program which is loaded when the MegaDrive boots[2].
Breakpoints
are implemented by writing the illegal instruction opcode to the
breakpoint address, and replacing the illegal instruction vector with
the monitor address (0x400000). When the 68000 hits the illegal
instruction, it throws an exception and thereby returns control to the
monitor.
Single-stepping is implemented using the trace
feature, which is a bit in the 68000 status register which when set will execute only
one instruction in user mode, then throw a trace exception, which also
brings control back to the monitor.
The debugger has read/write
access to the 68000 registers because the first thing the monitor does
when it starts is to save the registers to a known region of SDRAM,
where they can be read (and updated) by GDB. When the monitor exits, the
last thing it does is to restore the 68000's state from that region of
SDRAM (picking up any changes applied in the meantime by GDB).
[1] My
SDRAM controller in the FPGA is able to interleave accesses by the host
with accesses by the MegaDrive. This makes the SDRAM effectively
dual-port.
[2] This conversation is achieved using an arbitrary binary
message-passing scheme, where the host writes a command-code and a payload to an agreed region of SDRAM, and then triggers the command by
writing to a semaphore. The host then polls that semaphore waiting for
the MegaDrive to update it with "I've finished", whereupon the host
reads the response payload from the same agreed region of SDRAM.
How does the bus-cycle tracing work?
Whenever the MegaDrive reads or writes to memory or one of its hardware registers, the address and the data read or written is available on the cartridge slot, so the UMDK cart can snoop on accesses to any[1] memory region. The snoop results in nine bytes of data, including:
- A 20ns timestamp
- Whether the source was the CPU or some sort of DMA
- Whether it was a read or a write (high byte, low byte or both bytes)
- The 23-bit address
- The 16-bit data read or written
The FPGALink-implemented USB interface is capable of doing 42MiB/s which is several times faster than what is required for bus tracing a MegaDrive, but the USB output pipe is fairly bursty, so on each bus-cycle the nine bytes of trace data are added to a wide, deep FIFO which acts to smooth out the USB burstiness. And when the trace data gets to the host side it is written to disk in chunks 64KiB at a time.
[1] In fact, some cycles cannot be snooped for some reason, like reads from the MegaDrive's onboard RAM. Writes are visible, reads are not.
makestuff
Jesse
Stefan Wagner
land-boards.com
Johannes le Roux
Hi,
I want to learn to develop for the Sega Mega Drive and I'm also used to deploying and debugging code to those old PDAs via USB in Microsoft Visual Studio.
So I really want to build one of these but it appears time has matched on fit this XC6SLX9?
Is there anyway for me to update this project with a recent, much cheaper FPGA?
Or is moving from Spartan-6 to Spartan-7 a complete revision of the design?
I have zero experience in this hardware side of things, but I'm guessing as the XC7 chips are all BGA and cannot be hand soldered I wouldn't be able to do this.
Is there a modern, cheaper FPGA out there that, seeing as it probably needs a new design anyway, could be used?
This is exactly what I want to have, to be able to set breakpoints and step through code with an attached debugger! 🤩
