Raspberry Pi Zero W GPS clock mashup
07/18/2017 at 22:02 • 0 commentsI've made a board that makes this project particularly easy - it's the SkyTraq Venus838LPx-T breakout board product I sell on Tindie, but there's a new variant designed to be placed over the first 12 pins of the Raspberry Pi GPIO header. It connects the serial GPS pins up to the two serial pins of the Pi, and PPS to GPIO 18 (pin 12). The GPS module gets power from the 3.3 volt supply, and the 5 volt supply is used to provide active antenna power with an AP2331 to protect from shorts and overcurrent.
This board plays nicely with any Raspberry Pi, but it plays particularly nicely with my Pi Zero W desk clock. If you use long pins on the GPIO header, knock out the GPIO cover on the case and stick this board on, you can follow the setup instructions here and on the Pi Zero W clock project and you wind up with a Stratum 1 NTP server that also has an accurate LED clock display. This combination, in fact, is ntp2 . kfu . com, which is part of the global NTP pool.
EDIT:
If you have one of my GPS Disciplined Oscillators, then this board will let you hook the diagnostic port of your GPSDO up to your Pi to make an NTP server. In fact, as soon as I get the board back from OSHPark, one of my Pi Zero W clocks with this board being fed from my lab GPSDO will be ntp1 . kfu . com.
Third place!
11/18/2016 at 05:23 • 0 commentsThank you so much to the judges of the Enlightened Raspberry Pi contest! This project was awarded 3rd place! I am humbled to be even mentioned alongside the other entrants.
This isn't the end of the story for this project by any means. Once upon a time I had designed a "Pi GPS cap" that added GPS to the correct GPIO pins.
I wonder if there's room in the world for a Pi Zero NTP GPS server adapter board. Such a board would combine a GPS receiver, a Pi Power buck converter and an SPI Ethernet adapter. Connect it onto a Pi Zero and simply add power, Ethernet and a GPS antenna for a tiny, two-board GPS NTP server.
What do you all think?
Nick Sayer
