What is this?
This is implementation of fiber optic sensors (FOS), ie. sensors where are no electronics at place, just optic fiber and some passive mechanical structures. FOS can be made to measure many physical quantities, like force, pressure, weight, temperature, vibrations.
Why bother, when we have electric sensors for this?
Electric sensors are great for a lot of applications, but there are environments, where those aren't usable - like measurement of temperature inside power transformer, strain on high voltage lines - and electric sensors would be upset by this conditions. Also, there are examples where voltage in those sensors - though not being particularly high - can be potentially dangerous for the environment, like danger of sparking around explosive materials.
But you need some electronics with FOS, right?
Yes, usually you need to emit some light into the fiber and also look at the sensors response, with photodiode, amplifiers, ADC etc. The point is that those could be fairly far away from measured point, with potentially hostile environment and signal is transferred by optic fiber. This has also another implied advantage - the 'fairly far away' can be like hundreds of meter, perhaps kilometers. In comparison with electronic sensors - there is usually problem to have electronic sensors that far away.
That looks complicated and expensive
Not that much, really. Multimode fiber can be bought for 0,15E/m, or at local telecom company for free as waste material, the rest is just basic electronic components available at your usual supplier. Two channel sensor similar to what I did can be made for 5-10USD, if you use cheap arduino compatible board. No other special tools are needed. All my knowledge is here, sources are on github, I used FOSS to build this.
In comparison, professional FOS solutions are at price at least two orders of magnitude higher.
jaromir.sukuba
This sensor takes advantage of flexibility of plastic to allow pushing rod movement.
or in slightly different view
It's made of three different kinds of 3D printed parts, in order to keep it simple and printable on average home printer.
Suspension is to be added on the four pillars, leading upper part with pushing rod against flexible material in empty space in bottom part.
I only had 2,5mm OD brass bar, because that was what I had available. The magnets do have 3,2mm ID, so 3mm bar would be better fit.
Plandeka
Minimum Effective Dose
