The photo above shows the camera streaming over ethernet (the same software but part of the ROV build - see here https://hackaday.io/project/158799-sphere-rov-8bitrobots). While the latency over WiFi was ~160ms, here the latency is ~100ms which is a nice improvement if your robot happens to be connected with a wire.
