The first 8BitRobots robot is a robot ball. The picture below shows the exploded design.
The ball is constructed from several 3d printed parts and a few other bits:
- 3D Printed:
- 2 Hemispheres which form the ball case as well as acting as the wheels.
- The main frame to which all the other pieces are attached.
- Battery clip, which holds the battery holder.
- The 8BitRobots standard module enclosure.
- Extras:
- Two micro, continuous rotation servos to drive the wheels.
- Two M2 bolts to hold the wheels on.
- Some wire and a switch to wire the batteries to the module.
- 6 AA battery holder.
- A few zip ties to hold the pieces together.
