If you're following the instructions to build your own 8BitRobots distribution, you may find the compilation fails with errors like the following:
undefined reference to `__atomic_fetch_add_8'
While I'm not entirely sure why this happen, a fix is described here https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=874531
The easiest way to apply this it to locate the various Makefile where the build fails, find the LIBS= directive in each one, and add -latomic to it.
LIBS = -latomic
Restart and the compilation should move on.
