Had a little time to solder the through-hole stuff.
Popped a Pi Zero into the socket with the 8BitRobots software on an SD card, added power, and up comes the board! So happy. Detects and configures all the I2C devices (as you'd hope). Next step is to validate all the external I/O connectors.
