ESP8266 Multi-tool
An ESP8266-based, inexpensive, diagnostic and debugging tool
My objective here is to fill a niche that I often find myself needing, working in a laboratory/R&D environment. I need an inexpensive device to perform lightweight datalogging and automation type tasks. The ESP8266 is a fantastic candidate for this, with the onboard wifi and blazing fast microcontroller.
I envision a "swiss army knife" of sorts, that is good enough for the task, and cheap enough to be almost disposable.
Using an ESP8266 Multi-tool, one could connect to test points in their circuit, and record and interact with the circuit through a web-based interface.
Log voltages, digital pin and bus states, and serial communications, all from a web page with ease. Conceptually, think a hardware version of "PEEK and POKE" from the days of BASIC.
Must meet requirements
  • At least one analog input channel,  ±12V-ish
  • At least one digital input for triggering, configurable via software
  • At least one digital output, configurable via software
  • Low power usage
  • Wide input supply range (3.3V-12V?)
  • Reliable time source for data acquisition (low jitter, high accuracy)
  • Web-based user interface for configuration of settings such as:
    • ADC Gain
    • ADC Sample rate (continuous, triggered on input, etc.)
    • Digital I/O (logging/output/triggering)
Stretch Goals
  • At least one analog output channel
  • Onboard storage for datalogging
  • Serial port with web interface (RS232 TTL)
  • "Bus sniffer" for SPI/I2C
  • Battery power option
Potential issues
  • How do we make it as small/cheap as possible?
    • Pre-soldered ESP modules must be weighed against raw chips as an option
    • Power the multi-tool from the device under test
    • Small pitch connector for test probes
  • Is input protection critically essential?
    • If the device is cheap enough, can we skimp on input protection?
    • What are the safety ramifications?
    • The multi-tool is not designed with high voltage measurements in mind
Typical usage case
  • I need to measure and record the input and output voltage of a circuit I've built, but a typical datalogging setup isn't suitable.  Maybe I'm in the back of the shop, rather than at my bench.  Maybe I'm not near my datalogging computer?  I can connect an ESP8266 multi-tool, and do my datalogging wherever it suits me best.
  • I need to measure and record a few choice signals on a piece of equipment that a customer is having intermittent issues with.  I can install an ESP8266 multi-tool, configure it to record, and come back tomorrow to download and analyze my data.
  • I need to record a voltage, while simulating an input signal, and I want them to be synchronized.  An ESP8266 multi-tool allows me to do just that, with its analog input recording and digital output pins.
Conceptual design, the multitool connects directly to a device under test, measures and records the selected signals, and displays them on your phone or computer.
JPEG Image - 2.60 MB - 04/23/2018 at 05:39
Preview
JPEG Image - 2.13 MB - 04/23/2018 at 05:39
Preview
The ESP-8266-12F is wired up to a breadboard adapter, since it has a smaller pitch than the standard 0.1" solderless breadboard.
JPEG Image - 3.51 MB - 04/23/2018 at 05:38
Preview
JPEG Image - 4.15 MB - 04/23/2018 at 05:38
Preview
The ESP-8266-12F Module
JPEG Image - 316.73 kB - 04/23/2018 at 05:38
Preview
  • 1 × ESP8266-12F WiFi microcontroller module
  • 1 × ADS1118 2/4 channel SPI ADC, 860Hz, 16-bit, with temperature sensor
  • Let's Get Started!
    netbeard04/23/2018 at 05:36 0 comments
    I've begun wiring up some parts on a breadboard, to evaluate the ADS1118 as a possible ADC candidate.
    I do have prior experience with this ADC, and it seems like a good candidate, with the 4-channel input and built-in temperature sensor.
    The ADS1118 is on the little adapter board.
View project log
Iamkhalidmanzoor786 wrote 12/25/2023 at 11:23 point
I really liked this one for my project like https://croxyproxy.site/ CroxyProxy
skt54557 wrote 04/11/2023 at 10:21 point
Meta Tags Generator are a crucial part of the on-page optimization process. With our free meta tag generator tool, you can easily create titles, descriptions, meta images, keywords, and index properties for your web page. You can even copy the code our tool generates and paste it directly into the head section of your page. Simple and easy!
