Hackaday.io Hackaday.io
Sign up Log in
ESP8266 Screen Set WiFi Credentials
Transfer data (WiFi credentials) from your smartphone to an ESP8266 by Pulsing your Smartphone Screen
eduardo-zolaEduardo Zola
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.3k views
5 comments
51 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 5
  • The 2018 Hackaday Prize
View Gallery
4.3k
5
51
42
Team (1)
  • eduardo-zolaEduardo Zola
Join this project's team
  • ESP8266-ScreenSetWifi
completed project
MISC
2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
cool
cool stuff
This project is submitted for
  • Hackaday.com Tip Line
  • Open Hardware Design Challenge
This project was created on 04/23/2018 and last updated 8 years ago.
Description
To setup your WiFi Credentials put your ESP12F over a Smartphone screen, and let the Black and White Oscillation transmit the information. Note: You need to cover the LDR, in a way no light can enter. The LDR should not touch the screen, it needs stay some millimeters far from the screen.
Items required:
- ESP-12F (and all the basic componentes to make it work)
- Resistor 300k
- LDR 50K-50M Omhs (GL5539)
- Unzip the library ESP8266-screenSetWifi-master (attached in this projet) into your Arduino Library Folder
PS: You can try other variations of resistor values and LDR types. Just make sure the max resistive value of LDR is greater than the pull-down resistor.
Github:
https://github.com/egzola/
Details
Files
esp8266_screenSetWifi-master.zip
x-zip-compressed - 3.22 kB - 04/23/2018 at 14:24
Download
screenSetWifi.zip
x-zip-compressed - 3.43 kB - 04/23/2018 at 14:24
Download
Log In/Sign up to comment
Sign up with Github
OR
Duke Circuit Co.,Ltd wrote 05/03/2018 at 01:12 • point
Is it work like a scanner?can take a video,how it work?
Louis Lo wrote 05/02/2018 at 17:57 • point
I am implementing exactly the same idea. But you did faster than me. :-)
morgan wrote 05/02/2018 at 17:52 • point
Very cool! I tried this same thing last year and hadn't succeeded. I started with an LDR setup like yours and had terrible results. Moving to a phototransistor helped but I still never quite managed it. Time to revisit I guess.
Dillon Nichols wrote 05/02/2018 at 17:17 • point
electric imp has a similar technology called blinkup https://electricimp.com/platform/blinkup/
ch.dugasduvillard wrote 04/26/2018 at 13:34 • point
Interesting project! How much time does it took to get the information?
Basically, the project will transfer data with DHT11 over wireless through NodeMCU. This transfer will be done by using an AndroidThings
Project Owner Contributor
Getting Temp, Humidity Information with Android Th
amilŞamil
Get notified when there is a change in the number of followers of your Twitter account and display status parameters via ESP32.
Twitter Follower Notifier
kutluhan-aktarKutluhan Aktar
Straight forward Info screen utilizing WiFi of an ESP32 and 7 Color ePaper technology
ReadMePaper
kc1r74pkc1r74p
A Personal Weather Station that displays current climate conditions on your desk using a bright, colorful OLED screen.
ESPecter | IoT Weather Station
acrobotic-industriesACROBOTIC Industries
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266 Screen Set WiFi Credentials", please tell us the reason.
Send message
Remove Member
