1Step 1
Obtain or produce the sub assemblies pictures above (See github for detailed assembly instructions, gerbers, and STLs): Polycarbonate front cover. Encoder PCB, Top housing, LCD, Knob, Main PCB, Paddles, Battery, Bottom Housing, screws and washers.
2Step 2
Connect battery to Main PCB, and set both into Bottom houssing
3Step 3
Connect LCD module to main PCB
4Step 4
Place Encoder PCB over boss on Top housing and place both onto Bottom housing and Main PCB
5Step 5
Place Polycarbonate front cover onto Top housing
6Step 6
Install 5 countersunk M3 screws though Front cover
7Step 7
Place paddles between paddle mounds and install 2 panhead M3 screws
8Step 8
Place Knob onto encoder shaft
Michael R Colton
