It is always a great feeling to get the physical boards from manufacturing :)
I had no real time to check the boards, but on the surface they seem fine. At least the connector measurements turned out ok and the board perfectly connects to the Pepino FPGA board.
The top of the board, photo taken through my magnifying glass / light:
Bottom side, with connectors mounted (no time yet for anything else):
A close up of the connection to the Pepino, it appears the SD card and audio jack are still accessible:
