NeoPixel_color_tuner2_v0-2.ino
Updates sketch, for the Trinket 3v 12 MHz. The TFT display doesn't overwrite characters with a blank background, so I use "fillRect" to black-out over the previous color values, then write the new values. These functions necessitate an added delay so you can read the new values, and that makes the update timing on changes to the slider-pots feel a bit sluggish. A faster CPU would help. Perhaps I should have used a Teensy.
ino - 14.13 kB - 05/01/2018 at 23:00
Download
Open for testing and debugging.
JPEG Image - 327.17 kB - 05/01/2018 at 22:54
Preview
This is hidden, once the unit is assembled. The FTDI-friend cables inside needed some hot glue, since power and ground cables are no longer locked in the connector.
JPEG Image - 307.88 kB - 05/01/2018 at 22:54
Preview
