I've made some good progress cleaning up the code, going from rough POC hacks to a more solid design th build off from. The next big change will be to add in support for more than one sensor. I also have now converted the angle information from a time into proper angles.
I mentioned earlier how stable the signal is. Below is an example of a sensor placed ~15 ft (4.5m) from the lighthouse. The sensor is near the center of the lighthouse's field of view (90 degrees is centered in X and Y), although I don't expect that to affect precision.
Units are degrees.
74.7528 96.7279 74.7538 96.7282 74.7540 96.7269 74.7543 96.7285 74.7556 96.7264 74.7558 96.7274 74.7556 96.7300 74.7538 96.7261 74.7553 96.7282 74.7538 96.7264 74.7538 96.7282 74.7497 96.7292 74.7530 96.7277 74.7530 96.7267 74.7533 96.7277
