Full rocker-bogie suspension
JPEG Image -
2.15 MB -
01/25/2017 at 21:12
Preview
Full aluminum scissor frame
JPEG Image -
2.28 MB -
01/25/2017 at 21:12
Preview
Evolution of the frame lift cam - top to bottom, ends up being 2/3rds of original design
JPEG Image -
835.55 kB -
01/08/2017 at 00:13
Preview
Extended frame with partial deck
JPEG Image -
2.02 MB -
01/08/2017 at 00:09
Preview
Partially extended/retracted frame top view with preliminary deck.
JPEG Image -
2.17 MB -
01/08/2017 at 00:09
Preview
Full side view of extended frame without decks
JPEG Image -
2.25 MB -
01/08/2017 at 00:09
Preview
Extended frame without decks from base end
JPEG Image -
1.95 MB -
01/08/2017 at 00:09
Preview
Diff with motor drive to lift rocker-bogie assembly
JPEG Image -
769.19 kB -
12/23/2016 at 01:48
Preview
Work table at end-of-day - very organized!
JPEG Image -
920.51 kB -
12/23/2016 at 01:47
Preview
Attachment of frame end-posts to differential shaft
JPEG Image -
900.18 kB -
12/23/2016 at 01:47
Preview
Base end-post pivot motor assembly
JPEG Image -
616.51 kB -
12/23/2016 at 01:46
Preview
Testing frame end-post and extension scissor units
JPEG Image -
727.95 kB -
12/23/2016 at 01:46
Preview
JPEG Image -
793.91 kB -
12/23/2016 at 01:45
Preview
Bunch of printed connectors
JPEG Image -
549.58 kB -
12/23/2016 at 01:44
Preview
Frame end-post and rocker-bogie sub-assembly
JPEG Image -
678.63 kB -
12/23/2016 at 01:42
Preview
Scale of stanchion holders
JPEG Image -
493.87 kB -
12/23/2016 at 01:44
Preview
Assembled diff. with motor gear
JPEG Image -
795.29 kB -
12/23/2016 at 01:43
Preview
Rocker-bogie n wheel assemblies
JPEG Image -
674.58 kB -
12/23/2016 at 01:43
Preview
Frame retraction cam design and prototype print.
JPEG Image -
512.84 kB -
12/23/2016 at 01:43
Preview
Layout of linear sub-system
JPEG Image -
827.39 kB -
12/23/2016 at 01:42
Preview
ServoCity components
JPEG Image -
889.40 kB -
12/23/2016 at 01:40
Preview
Delivery of ServoCity order
JPEG Image -
1.22 MB -
12/23/2016 at 01:33
Preview
Basic 2D design of partially extended frame - minimal detail, no motors or control systems.
Portable Network Graphics (PNG) -
65.43 kB -
10/13/2016 at 20:35
Preview
Ultimate vision of what the frame could be!
298.46 kB -
10/13/2016 at 20:42
Preview
A simple version of a frame reaching right into the water with floats.
357.50 kB -
10/13/2016 at 20:42
Preview
A staircase version of the extendable frame.
433.09 kB -
10/13/2016 at 20:42
Preview
The compact nature of the frame folding with rocker retraction
343.06 kB -
10/13/2016 at 21:11
Preview
Close-up of wheelbase
265.47 kB -
10/13/2016 at 20:46
Preview
Close-up of frame
237.86 kB -
10/13/2016 at 20:46
Preview
Rocker-bogie offers great stability as is well understood - however, tests show that without independent drive the frame would drift due to the asymmetric rolling experienced between arms over terrain
359.67 kB -
10/13/2016 at 21:34
Preview
Kinematic trace of frame, rocker, bogie and wheels over uneven terrain
JPEG Image -
52.05 kB -
10/13/2016 at 21:35
Preview
Uneven terrain that can be handled.
494.58 kB -
10/13/2016 at 21:35
Preview
Tested various scissor beams to understand strongest design and then optimized for - saved approx 30% on material while retaining same strength.
399.44 kB -
10/13/2016 at 21:35
Preview
Tested various frames to simulate supported and unsupported (overhang) strength.
295.54 kB -
10/13/2016 at 21:35
Preview
