1Step 1
Make sure your enclosure box is large enough for the cat and the treat box/arduino. If you're not sure enough check out the photos in the first experimental log. (See how I linked that - You can link project logs into instruction steps)
2Step 2
Build the treat box. Check out that link to a project log with the details!
Adam Fabio
