The idea here is to pre-treat some small fabric/microfiber pads with something that will trigger the glue to cure instantly. I tried some Zip-Kicker, but the results were underwhelming - perhaps the active ingredient evaporated? There are other - even reasonably non-toxic substances that will rapidly cure cyanoacrylates. Baking soda seems to be the best option. Next time I will try to work some baking soda into the pads.
oneohm
