V3 assembled
09/14/2017 at 19:50 • 0 comments -
Version 3. Back to ATMEGA328
07/19/2017 at 09:08 • 0 commentsBecause I have lot of interest in Tindie store, I am decided for simple version with atmega328, which is much more easy programmable without special programmer and also with standard 4digit segment display
Display test
01/11/2017 at 13:46 • 1 commentfirst board assembled.
SAMD21 and display working :)
Boards for v.2 received
01/09/2017 at 10:23 • 0 comments- Arduino Zero compatible Atsamd21e18
- Custom 0603 led matrix 22x5 LED - project details
- DS 3231 Precise RTC with CR2032 backup battery
V1 boards for sale.
11/28/2016 at 11:09 • 0 commentsHi, If somebody want make this useless thing, I selling boards from prototype batch.
Firmware is very basic now, If you want make better code ... lets go ... :)
New V2 boards ordered (ARM SAMD21)
11/23/2016 at 07:22 • 0 commentsNew boards ordered.
Features:
- AtsamD21E18 - arduino zero compatible
- DS3121 with backup battery.
- Micropython support
- 5x22 LED display from this project charlieplexed-matrix-display
- USB for upload firmware
- Power switch
First test - video
11/19/2016 at 10:37 • 0 comments -
Boards received
11/03/2016 at 13:38 • 0 commentsBoards received and case assembled ...
Boards ordered
10/17/2016 at 21:51 • 1 comment![]()
PCB done
10/13/2016 at 21:59 • 0 commentsAlmost finished pcb design.
I separate batch to 2 batch:
1. back and side boards
2. top and cpu board
It is more versatile if I found error on CPU board I can use back boards
I am back focused for mega328 ... samd21 is prepared for next version with discrete leds matrix and micropython
bobricius
