1Step 1
Packages had been severely 'munged' during shipping, but nearly everything survived, a testament to the machine! The acrylic "Guard" had broken... I wish I didn't fix it, cause it just gets in the way
2Step 2
Hardware:
Medium Machiney Benchtop Injection Molder; 5CFM+ Air Compressor (Harbor Freight 10Gal, 2.5 Horsepower, $130) {plus adapters & fittings} ; Toaster Oven ($80); kitchen gram/oz scale; stop watch;
Tools:
channel-lock & needle-nose pliers, diagonal cutters, metal spatula, flat end screw driver, heavy duty grill grate, plastic measuring cup, plastic funnel & tubing,
Consumables:
HDPE pellets,
3Step 3
Additions to the Machine:
I penciled in the line-up point of my mold, to the faceplate of the bottom bracket. I may make a laser cut tool for it later.
I created a set of rulers on the side of the machine to gauge the shot size/volume/weights that I will be using...
4Step 4
Assembling the Machine:
Be sure to follow the directions carefully... also make sure you insert ALL the wires into their ports...
5Step 5
Using the Injection Molder:
Allow the machine to preheat for 15 minutes
you bet! I'm working on my test part right now! Expect new developments over this week AND by the end of the month!
Awesome, thanks for the write up. Can you provide more information on making a mold and the resulting plastic part quality?
