OK, some progress to report:
I reconfigured the M8047 back to default settings (except for baud rates). Set SLU1 to 300 baud and connected to a Silent 700 terminal. Powered on and...nothing. Turns out the 1A fuse on the +12V line on the M8047 was blown. I don't have any proper replacements right now (Littlefuse PICO II is a good replacement), so I ordered some and temporarily replaced the blown fuse with a jumper. Now I get console ODT output when I power it on (yay! That means the power-on sequencing circuit is working!) but it will not accept input from the keyboard. This could be a cabling issue, or possibly a blown UA9637 receiver (or ...). All I know at this point is that the RRI pin on the UART is stuck at logic 1.
More to come...
...and as promised:
It does appear that the UA9637 is fried. I can trace the TTY output on the oscilloscope to pin 5 (2 IN-), but there is no change on pin 3 (2 OUT).
Guess I need to make *another* Mouser order...
