Z-axis Update
05/16/2018 at 21:21 • 0 commentsZ axis tensioner update:
- smaller and lighter design (and less to print)
- simplified the design by reducing the number of parts
All updated files available for download at my github page.
Will add it here later...
apr addon progress
04/30/2018 at 14:50 • 0 commentsPrinting parts for apr addon for testing purpose and future firmware modification to run apr from g-code (or m-code)
Project update:
-added latest rev of apr addon .stl files
-updated part_list.xls with latest assembly
-updated project renders
Automatic parts removal addon
04/29/2018 at 20:32 • 0 commentsFirst CAD of automatic parts removal addon for existing heatbed. It's driven by 25D geared dc motor. Belt made from strong PET sheet if needed will add some metal sheet later. Belt tensioner needs to be added and need to think about a fine way to make an closed-loop out of my PET sheet (first thought temperature?)
More work need to be done... right now it's a basic concept...
Gathering parts...
04/28/2018 at 12:02 • 0 commentslong pet sheet + two steel shafts covered with silicone from a laminator = small automatic parts removal system progress :)
Printing latest panel cover parts
04/27/2018 at 16:01 • 0 commentsPrinting right now the latest version of sunbeam 2.0 panel cover. This one should be better alligned with the panel pcb.... and no it’s PET so once again... bye bye PLA.
PET sheet build surface test
04/26/2018 at 17:07 • 0 commentsIf you want to perfect stick your 3d prints vinyl is cool but when printing with PET on vinyl you detach it with a piece of sandpaper ;)
SOLUTION: PET sheet. 3d Prints stick perfect and detach without any problems when heatbed is cooled down.
PLA keychain
04/26/2018 at 17:00 • 0 commentsone of the first protoDEV 3d print...
PLA on vinyl sheet
04/26/2018 at 16:58 • 0 commentstest print on vinyl sheet build surface
PET 3d print preview
04/26/2018 at 16:56 • 0 commentsPET chess 3d printed on protoDEV
