13D Enclosure
1) 3D print and post-process the mechanical enclosure
2) apply brush on coating for all 3D printed parts (optional)
2Wheel preparation
3) push in the skateboard bearing in to the back of the wheel.
4) Epoxy 2 magnets in to the magnet holders with their polarity in the opposite directions (Note: it doesn't matter what direction each magnet is facing as long as their polarity is in opposite directions).
5) Epoxy 4 suction cups to the back of mount
3Soldering Sensors to Photon Battery shield
5) Clip away stack-able headers on the bottom of the photon battery shield
6) Solder the following wires:
PIR Digital out --> Photon Digital Pin 4
PIR Power --> Photon 3V3 Pin
PIR Ground--> Photon Ground Pin
Hall-Effect Signal (Green) --> Photon Digital Pin 2
Hall-Effect Power (Red) --> Photon Digital Pin 5
Hall-Effect GND (Black) --> Photon Digital Pin 3
4Securing Sensors to 3D enclosure
7) Connect all jumper wires to the appropriate PIR header pins
8) Secure PIR sensors using 4 #2X1/4" screws
9) Secure Hall-Effect sensor to the mechanical enclosure using 2 "Nylon Slotted Flat Head Screws" and "Low-Strength Steel Hex Nut"
5Bringing it all together
